Author Topic: Car losing a LOT of coolant!  (Read 4078 times)
SMD
  • London
    • :( nowt
« on: 01 September 2010, 20:59:56 »
I topped it up yesterday when I got the warning on the computer and twice today (roughly 2-3 litres total). As I drive up to my parking slot I can see a long trail of coolant left behind on the road.  :-[
Whats the cause and whats the fix?
Cheers
Welung666
Re: Car losing a LOT of coolant!
« Reply #1 on: 01 September 2010, 21:01:23 »
When you look underneath where is it dripping down?
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 01 September 2010, 21:01:37 »
Investigate exactly where the coolant is leaking, and you'll have a much better idea of how to fix it.  Could be anything.... even something as small as a split hose.
« Reply #3 on: 01 September 2010, 21:03:25 »
Big loss is most likely the bypass valve....sudden spectacular loss, the helter skelter pipe from bypass valve to engine
SMD
  • London
    • :( nowt
« Reply #4 on: 01 September 2010, 21:13:48 »
I can see it dripping from something thats behind the engine oil sump (if that makes sense).
Will check the passenger footwell but dont think there is any water there, heaters work fine although I am finding it difficult selecting gears since this happened (probably unrelated and coincidental)
« Reply #5 on: 01 September 2010, 21:15:03 »
Bypass valve is favourite then.....
SMD
  • London
    • :( nowt
« Reply #6 on: 01 September 2010, 21:18:42 »
So new bypass valve...how much is one of those and can it be changed at the side of the road?
« Reply #7 on: 01 September 2010, 21:23:03 »
Best thing to do is look at it first, check for traces of water staining
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #8 on: 01 September 2010, 21:34:55 »
twenty to thirty quid, maybe not even that, and yes it can be changed without the need for shelter!  :y
PM with your requests.
humbucker
  • Cambridgeshire
« Reply #9 on: 01 September 2010, 21:36:51 »
« Reply #10 on: 01 September 2010, 22:09:48 »
Sounds like HBV mate - ~£30 from Vx - don't get pattern get genuine Vx.
Bit fiddly to get at and remove hoses/clips - best to remove scuttle and plenum to make life easy.  Altough I didn't remove skuttle last time I changed one.
HTH
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #11 on: 01 September 2010, 23:50:19 »
remove the scuttle and the black support plate
ScaniaV8
  • Luton, Bedfordshire
« Reply #12 on: 02 September 2010, 08:42:54 »
I paid £36 for new genuine VX HBV valve. Only fit a genuine otherwise false economy!.
I am a novice mechanic but followed the excellent maintenance guide and it took about 2.5 hours. Most experieneced mechanics will change it in 30 minutes I guess.  Definitely remove the scuttle for better access to the HBV....and do be patient...and expect a few skinned knuckles....plasters to the ready ! :)
Good luck.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #13 on: 02 September 2010, 08:49:07 »
Good luck.
& a swearbox ;D
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #14 on: 02 September 2010, 09:39:15 »
Good luck.
& a swearbox ;D
Had to do mine a few weeks ago and my swearbox was full by the end.... Not a bad job with the help of the very good how to. As said it cost me £37 for a new one from the sellers.
« Last Edit: 02 September 2010, 09:42:32 by SP_3.2 »
Page created in 0.025 seconds with 20 queries.
