Author Topic: brake problem  (Read 1858 times)
ianc
  • moreton merseyside
brake problem
« on: 08 September 2010, 20:46:13 »
cliking noise under car when i apply the brakes,also ther not that great where do i start looking first
Kneepad
  • West Scotland
Re: brake problem
« Reply #1 on: 08 September 2010, 21:26:10 »
Check brake discs and pads. Then check all suspension jounts and bushes.
Bent valve
Re: brake problem
« Reply #2 on: 08 September 2010, 21:35:45 »
First thing to do is check your fluid level, and then whip the  wheels off and have a look at the discs and pads and renew any suspect parts. But if you need to ask this question it suggests that you may not have a lot of experience working on braking systems and if you are not confident you may be better getting one of the mechanics that frequent this site to have a look at them for you :y
ianc
Re: brake problem
« Reply #3 on: 08 September 2010, 22:02:02 »
how do i get in touch with them.
Kneepad
  • West Scotland
Re: brake problem
« Reply #4 on: 08 September 2010, 22:05:13 »
Hang about they'll be along soon.  :y
Knight3179
  • Stromness,Orkney
Re: brake problem
« Reply #5 on: 08 September 2010, 22:25:58 »
Check for obvious things,loose wheel nuts,etc, have a look at the balljoints on the track rod ends,if they're gone they'll be squashed and split, usually the cause of a click or a small knock when braking is a loose balljoint travelling,
Re: brake problem
« Reply #6 on: 08 September 2010, 22:34:25 »
ABS problem?...had this on a different car.. :-/
« Last Edit: 08 September 2010, 22:34:55 by floodm »
