Author Topic: alarm going off every 20 mins  (Read 4120 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 06 September 2010, 23:14:22 »
just started a few hours ago ....goes off for no reson when i go to the car, the interior light is on and when the key to turned to postion 1, there a buzzing sound.
Any tips on where to look at .
thanks
Steve :y
mh_trigger
Re: alarm going off every 20 mins
« Reply #1 on: 06 September 2010, 23:33:13 »
it happened to me a year ago.......disconnect the battery for half hour then reconnect it and wait and see  ;) thats what i done and it seemed to work.......couldnt tell you what was wrong tho! ::)
SP_3.2
  • Leicester
« Reply #2 on: 06 September 2010, 23:34:23 »
Thanks will give it a go when rain stops :y :y
Kneepad
  • West Scotland
« Reply #3 on: 06 September 2010, 23:35:35 »
 No idea what's causing it but there is a guide in the maintenance section on how to disconnect the Power sounder.     At least till you figure it out.
hotel21
  • The Kingdom of Fife
« Reply #4 on: 06 September 2010, 23:50:55 »
You been under the bonnet today?  Check the bonnet alarm switch has not been accidentally leant upon and pushed downwards, causing false alarms as its now out of position.
SP_3.2
  • Leicester
« Reply #5 on: 06 September 2010, 23:57:43 »
Under there a few days ago , topping up the washer jet tank. Have just been out and taken it off and given the switch a clean and check over. Locked up now.....will see if i get a 3am alarm call from the car.
Thanks for tip.  do you normal get the 4 beeps from the sounder as the battey is going, as i have not had that at any point so hope the sounder is ok.
gstylebaby
  • stockport
« Reply #6 on: 07 September 2010, 00:42:29 »
Steve have you got a push switch in the boot for light and alarm.  Only mine has gone a few times and it always end's up that its that on mine it tends to just ping out and end up in a few parts.  Worth a check if it does it again mate.  :y
SP_3.2
  • Leicester
« Reply #7 on: 07 September 2010, 02:05:57 »
Gone off again :( :( Not much sleep tonight...looks like it,s the powersounder....just to check it when i disconect the power sounder if i have to disconect the battey.
unclelicklug
  • Sheffield
« Reply #8 on: 07 September 2010, 08:23:46 »
Could be a total red herring - and time may prove me wrong but had similar myself, looking back this was coinciding with my remote key becoming unreliable and eventually dying.
Since I got the repaired remote back from Martin Imber (brilliant service as others have stated) the alarm seems to have settled itself. Touch wood.
Kneepad
  • West Scotland
« Reply #9 on: 07 September 2010, 09:16:23 »
Disconnect Powere Sounder:
http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
SP_3.2
  • Leicester
« Reply #10 on: 07 September 2010, 09:46:11 »
Had to drive into work today and was over night the alarm was still going off . Ended up putting it in the drive way. What i am finding is that when the key to turned to postion 1 there is a buzzing from the fuse box ( one of the white ones at the right of the box ).
Also had the intererior light staying on as i was driving . Checked all the doors and they where closed and lock.
Would this sound like to you guys as still the powersounder playing up. I have not been getting the 4 beeps at all.
Thanks
Steve.
« Reply #11 on: 07 September 2010, 10:13:14 »
Pop it round steve and we can have a little look for you.
SP_3.2
  • Leicester
« Reply #12 on: 07 September 2010, 11:11:13 »
Cool thanks Mark. Usual  time ok for you.
SP_3.2
  • Leicester
« Reply #13 on: 08 September 2010, 11:00:06 »
As a update to this , ran the car up to Mark DTM and the prob turned out to be the drivers doorside  light swich the rubber cover had a rip in it and was letting in water. With the rain a few nights ago it was triggering the alarm. Will be getting a new one from Vx sellers in a few days. Nice easy fix.
Many thanks Mark..nice to meet up and thanks for the Tech 2 check up.
« Reply #14 on: 08 September 2010, 16:08:37 »
Good old Mark/tech 2.
Just wondering though how does the diagnosis work with tech 2, does it give a code for the location of the door light switch maybe?
