Author Topic: Y26SE code 0560  (Read 5737 times)
joshwyatt
  • Oxford
Y26SE code 0560
« on: 08 September 2010, 19:31:55 »
I had to jump start a P38 Range Rover and a Merc Sprinter van today. My battery isn't the best in the world and when I restarted it I noticed I had the 'spanner' light come on with the ignition, goes out with engine running. No stored codes, and from the pedal trick I get 0560. Which says something about low voltage. I guess putting quite a high demand on the battery caused it?
Vehicle starts fine and there's nothing wrong with it, but is there anything I need to do to try and clear the code, or just wait?
Re: Y26SE code 0560
« Reply #1 on: 08 September 2010, 19:37:54 »
Just wait.  :y
Batterys not too bad on tc.
Re: Y26SE code 0560
« Reply #2 on: 08 September 2010, 20:45:33 »
Eh....how did you jump start said items?
joshwyatt
  • Oxford
Re: Y26SE code 0560
« Reply #3 on: 08 September 2010, 21:16:06 »
Connected jump leads from my Omega battery to the RR, got it started. Then moved on to the Sprinter. Sprinter took a few attempts to start, I think that's where my battery wasn't too happy.
I wasn't overly concerned, but something must have triggered the fault code, and I was wondering whether it needs to just be left or I need to attempt to do something about it.
Re: Y26SE code 0560
« Reply #4 on: 09 September 2010, 08:36:16 »
You need to learn how to jump start cars matey!
Re: Y26SE code 0560
« Reply #5 on: 09 September 2010, 19:36:08 »
Sounds like a guide could be useful, including usable 0v connections on the different engines ;)
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Y26SE code 0560
« Reply #6 on: 09 September 2010, 20:02:13 »
Meaning what? The op has not mentioned anything where you could judge him doing something wrong?
Re: Y26SE code 0560
« Reply #7 on: 09 September 2010, 20:09:43 »
.... including usable 0v connections  ....
meaning 'earth' in none electrickery speak! The whole world refers to the none positive connection as the 'earth' apart from here.  ::)
Are we all going to refer to things like the mass of our cars rather the the weight due to gravity????
Perhaps in a true electrickery world it might very well be technically a zero volt connection, but in all other circles of life it's the earth.  :y  :y  :y
Josh never said where he connected his jump leads to the other vehicles.  ;)
Re: Y26SE code 0560
« Reply #8 on: 09 September 2010, 20:27:41 »
Indeed he didn't, but I think we all know ;)
Re: Y26SE code 0560
« Reply #9 on: 09 September 2010, 20:30:07 »
I'd reckon the same way as CaptainZok was jumped  :y  :y  :y
Re: Y26SE code 0560
« Reply #10 on: 09 September 2010, 20:32:17 »
tut tut ;)
Re: Y26SE code 0560
« Reply #11 on: 09 September 2010, 20:59:57 »
tut tut ;)
you appear to be assuming  ::) ::) ::)
my engine was not running when the connection was made  ;) ;)
Re: Y26SE code 0560
« Reply #12 on: 09 September 2010, 21:05:49 »
tut tut ;)
Mkaes no difference if it is running or not ;)
Re: Y26SE code 0560
« Reply #13 on: 09 September 2010, 21:09:52 »
Give me your theory then  ;) I can't see a difference where you connect the earth,  the terminal, block or anywhere else, still the same potential as far as I can see.  :-/ :-/
  • Auckland
    • Mazda MPV
Re: Y26SE code 0560
« Reply #14 on: 09 September 2010, 21:24:44 »
It will make a difference if the earth strap is sh*gged. ;D
The important thing to remember is that jump leads are NOT capable of carrying enough current to drive a starter motor under load. They are only really suitable for fast charging or assisting battery a weak battery.
What has always worked for me is to attach the leads (to the battery terminals) with engine idling and then to hold the engine at a fast idle for a minute or so (to put some charge into the non starter) before trying to start the non-starter.
