Author Topic: Aux belt/pulley  (Read 1075 times)
beemerdevil
Aux belt/pulley
« on: 10 September 2010, 18:32:33 »
sorry guys.....ive searched for a 'how to' but couldnt find one (probably missed it) of changing the aux belt tensioner pulley? - any one got the link plz? TIA  :y :y :y
Re: Aux belt/pulley
« Reply #1 on: 10 September 2010, 18:41:36 »
ITs super easy.
15mm spanner on the tensioner bolt to release the belt tension and slip the belt off.
Using the same spanner, undo the tensioner pulley bolt and replace the pulley.
Release the tension again and pop the belt back on.
15 mins to do
beemerdevil
Re: Aux belt/pulley
« Reply #2 on: 10 September 2010, 19:02:27 »
cheers Mark... yea I thought it was as easy, just didnt know if any thing to watch for  :y :y
edit:  BTW is it advisable to change complete unit? (tensioner&pulley?)
« Last Edit: 10 September 2010, 19:42:46 by beemerdevil »
Re: Aux belt/pulley
« Reply #3 on: 10 September 2010, 19:15:25 »
THe run of the aux belt :)  ;)
beemerdevil
Re: Aux belt/pulley
« Reply #4 on: 10 September 2010, 19:26:21 »
[/highlight]
yea...roger that dbug  :y :y
Re: Aux belt/pulley
« Reply #5 on: 10 September 2010, 19:53:14 »
I disagree. The tensioner is normally OK & it's just the tensioner pulley that suffers from a failed bearing. It's available seperately too.  :y
« Last Edit: 10 September 2010, 19:53:59 by Andy_B »
Re: Aux belt/pulley
« Reply #6 on: 10 September 2010, 20:14:00 »
The tensioner will be fine
beemerdevil
Re: Aux belt/pulley
« Reply #7 on: 11 September 2010, 08:49:06 »
thanks guys for all your tips/info  :y :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Aux belt/pulley
« Reply #8 on: 11 September 2010, 09:51:35 »
I replaced my aux. belt a while ago, 3 miles later the tensioner failed leaving a large spring protruding from the engine bay.
The pulley still looks fine.
I'd replace the lot, belt tensioner and pulley.
Re: Aux belt/pulley
« Reply #9 on: 11 September 2010, 10:56:16 »
If the tensioner still looks OK (they are mega reliable), just change the pulley.  Its the pulley bearings that fail, as they have to do a lot of work
Page created in 0.022 seconds with 21 queries.
