Author Topic: help again please guys.....this thing is annoying  (Read 3909 times)
Canon Cam
  • Ferdown/bournemouth
« on: 04 July 2010, 15:17:00 »
OK, my wife's W reg 2.0 GLS auto is getting really annoyig now!!  getting to the stage that I might invest in £5 of petrol and torch the damn thing!!!
Here are the problem('s).
1) (most serious)  Car is hisitant and idles badly when in drive.  Easiest way to descibe it is that it feels like it is about to back fire and if I listen to it underneath sounds like a little "pop" in the exhaust.  When stopping at lights in drive, car "judders" and vibrates.
2) when at low speed and sterring on full lock (eg when reversing of the drive and turning, there is a screech - ala fan belt, but fan belt, main belts seems correctly tight.
3) exhuast sound "blowy" even though just had new system fitted.
THINGS DONE SO FAR:
cam gasket replaced a couple of months ago when oil was getting into spark plug wells.
New cat - old one destroyed and blocked so meant car broke down one day and had to be recovered.
Breather pips/tubes and ICV cleaned
new cam sensor.
new maf sensor.
THERE ARE NO FAULT CODES.
Anybody got any suggestions (other than the aforementioned £5 of petrol!) :-/
Re: help again please guys.....this thing is annoying
« Reply #1 on: 04 July 2010, 15:36:57 »
THINGS DONE SO FAR:
new cam sensor.
new maf sensor.
1) Check all connections on DIS Pack & especially the condition of the rubbers on the plug end. Check plugs are torqued correctly. Also clean the Throttle Bodyfit & fit a new gasket. Check all pipework/connectors for cuts/splits. Spray Carb Cleaner (carefully!) around the inlet/exhaust area of the Head & see if the engine note changes, indicating an air leak.
2) This is from the Power Steering Pump & probably due to wear, but check the fluid in the reserviour for both level & condition (should be red, if brownish, needs replacing). I've been driving mine with this problem for months now & I occassionally lose steering assistance at parking speeds but it will have to wait until funds are available :-/
3) Check the new joints for leaks, & also the Ex. Manifold to Head bolts for snapped studs as sometimes, unintentionally, a lot of stress is put on the Manifold & downpipe when fitting a new exhaust. Also check the Manifold for a crack, although you would probably hear this as a 'ticking' sound.
HTH,  :y
« Reply #2 on: 04 July 2010, 15:41:20 »
oil from previous cam cover leak may have buggered your ht leads, or plugs.
tired or low fluid in pas pump possibly, but they dont like full lock generally.
gat someone to stick a rag over the tail pipe while you search for the leak.
« Last Edit: 04 July 2010, 15:42:06 by chrisgixer »
Canon Cam
« Reply #3 on: 04 July 2010, 16:23:43 »
thanks for the suggestions so far.
One quikc quesion (looking into flea for leads/plugs).   Given my car is a W 2000, - mini-facelift I thnk.....what enging type is it (20XEV??)
    • 530D M Sport, 330i Coupe
« Reply #4 on: 04 July 2010, 16:27:13 »
X20XEV
Was the MAF a new genuine (Bosch) item? What happens if you unplug the MAF and run the car?
« Reply #5 on: 04 July 2010, 16:35:35 »
if you had a pattern cat fitted that will sound shite, like a system is blowing
Canon Cam
« Reply #6 on: 04 July 2010, 16:40:22 »
yeah, bosch one, and with MAF unplugged, symptoms same, and engine warning light comes on.   Does not come on otherwise.
Canon Cam
« Reply #7 on: 04 July 2010, 16:45:50 »
one other tinhg which may help you guys help me.
When in P or N, it is not too bad, when when in drive and stopped, or driving, it is worse  - maybe this is just because the engine is under more load?
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #8 on: 04 July 2010, 18:33:51 »
what is the engine idel rev speed??,, and have you clean'd this out.
Canon Cam
« Reply #9 on: 04 July 2010, 18:36:26 »
idle revs are around 800rpm
And yes.   small breather tube and hose was first port of call to clean out.  It was acutaly fairly clear, the larger (front) pipe on the head is a little cocked, but all cleaned now with carb cleaner.
same #same#
  • south yorks
« Reply #10 on: 04 July 2010, 18:43:06 »
when you take off fast at junction dose the egine make a burring noise sound's like coming from the exhaust???
« Reply #11 on: 04 July 2010, 18:50:43 »
Too high. Are you sure there`s no vac leaks. When you did the ICV and breathers did you use a new gasket for the throttle body, did you clean the small hole in the body, did you check all breather hoses were free of splits. Have you checked the large air inlet hose to throttle body for splits
« Reply #12 on: 04 July 2010, 18:55:43 »
as philrich said I would check the ignition components initially..
and try a known good icv..
and for the exhaust, if consumption is higher than usual there must be a leak .. even a needle head size hole can cause this..
« Last Edit: 04 July 2010, 18:58:03 by cem_devecioglu »
« Reply #13 on: 04 July 2010, 18:59:36 »
I`ve got a genuine dispack with leads. Secondhand but all known good if you want to go down that route
« Last Edit: 04 July 2010, 19:01:54 by RobG »
Canon Cam
« Reply #14 on: 04 July 2010, 22:13:21 »
thanks guys,  will investigate further tomorrow.
When it is in drive and at idle, it now sounds pretty much like a knocking baning at bottom of engine  :-[
Page created in 0.023 seconds with 16 queries.
