Author Topic: Taking a guess, is it dead?  (Read 3419 times)
Teebee
  • Slough
Re: Taking a guess, is it dead?
« Reply #15 on: 13 September 2010, 10:08:42 »
Sorry TB further up I was referring to the ABS ECU I just didn't mention it again in the last post.
Teebee
  • Slough
« Reply #16 on: 13 September 2010, 16:01:05 »
If the coolant servicing has been historically poor, I've seen oil cooler plates corrode badly, which normally leads to a massive leak.
Well i've stripped it down to the inlet manifold and all the pipes into the bridge area are dry and intact, if I add water you can see it run both directions under the manifold so looking like your guess is right and the oil cooler failed. I need a proper torx set to get lower as a few bolts are solid but I will get there for my own interest.
« Reply #17 on: 13 September 2010, 18:15:38 »
Opps  :-[
Are both cars pre 1998 or both post 1998?  The ABS hydraulically changed with minifacelift, going from 3 channel to 4 channel.
If the answer to that is yes, then as long as they are both from same engine adn gearbox setup, should be fine.
