Author Topic: Headlight adjusting (auto)  (Read 3168 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: Headlight adjusting (auto)
« Reply #15 on: 14 September 2010, 00:10:04 »
Thanks Andy and others....its really much appreciated :y
« Reply #16 on: 14 September 2010, 10:10:08 »
Just to add to this, I find the Allen key adjuster on the front of the light sometimes does not engage the nylon wheel at the back as said, you can help it turn by placing a spare hand at the back of the light and turn the nylon gear and allen key adjuster at the same time, in fact as they are so fragile I would suggest that as standard procedure tbh.
These will need several turns to achieve very little adjustment, so suggest park the car close to a garage door or similar and watch the beam for movement, if it moves sideways you have the wrong adjuster. Once you have sussed which adjuster and which way to turn it(if the adjuster is not broken of course)....
Drive the car as close as possible to a garage door or wall, lights on, mark the position of both beems, reverse up 6feet or so and adjust the beam so the new position sits about an inch below the previous mark.
 Note, there is a marking somewhere on the headlight that gives the ratio of dip per distance of beam. By working out this ratio, the percentage of drop from the mark on the door can be calculated from the distance the car is reversed up. But I never bothered with that  ;D
Reverse up 6feet and adjust to give an inch drop, then drive the car at night, adjust from there.
Do try to get it right though, too high beam is very annoying. :y
« Last Edit: 14 September 2010, 10:12:30 by chrisgixer »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #17 on: 14 September 2010, 19:57:45 »
Good reply, buddy. :y
I fully appreciate how annoying it is to be dazzled....I cringe every time a car comes towards me, waiting for the dreaded flas, flash :( :(. Not using the car at night now, until I sort it. :y
I have been trolling through the forum for any info and your reply, mate condenses all I have found. Been twisting the adjusters, but have been poncing about with quarter turns ;D ;D instead as you and others suggest ...mega turns.
As a last elimination...if the headlight motors were not working, would that show up the Low Beam/Fld Vision fault light. I have not had that light since I renewed the rear sensor. ;)
« Last Edit: 14 September 2010, 19:59:03 by terbert1 »
