Author Topic: Outage 10th Jan  (Read 3497 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Outage 10th Jan
« Reply #15 on: 11 January 2008, 17:29:15 »
I have honestly no clue what on earth you lot are on about.....
I'm not the only numpty then!  ;)  ;)
Apparently Not  ;D
Re: Outage 10th Jan
« Reply #16 on: 11 January 2008, 17:34:47 »
Apparently Not  ;D
;D  ;D  ;D  ;D
Re: Outage 10th Jan
« Reply #17 on: 11 January 2008, 18:30:11 »
i would add that auto updates should always be enabled - too easy to be lax with manual....
WGA false positives when the WGA server when down
Nonsense. Utter nonsense.
If you're getting WGA positives, the system actually has to say that is the case.  Sure you ain't been sharing your licence?  Also, IIRC, your licence was OEM? If so, check if it was tied to a particular manufacturer.
Re: Outage 10th Jan
« Reply #18 on: 11 January 2008, 18:32:34 »
I don't have any experience of Linux running on Win via VMWare but it sounds awfully complicated. Could you not just run a separate Linux box - or am I missing something?
Jim
I could, but the advantage of multiple servers running on more powerful hardware is due to the 'bursty' nature of most servers, the virtual machines tend to run faster than if they were on a dedicated, but modest, hardware.
But the main reason is my £100 per month leccy bill - I really don't want to pay more!
Re: Outage 10th Jan
« Reply #19 on: 11 January 2008, 18:33:13 »
I have honestly no clue what on earth you lot are on about.... but it sounds good, and the Forum works every time I come on so keep up the good work TB  :y
Tis fairly basic stuff to be honest, nothing clever :)
theolodian
  • I need a new avatar.
Re: Outage 10th Jan
« Reply #20 on: 11 January 2008, 18:35:24 »
At least you can get VMWare to reboot the VM automatically.  ::) :-[
Re: Outage 10th Jan
« Reply #21 on: 11 January 2008, 18:36:44 »
LOL, the VM was fine, it was VMWare's subsystem that fails....
Martin_1962
Re: Outage 10th Jan
« Reply #22 on: 11 January 2008, 20:22:44 »
My machine - no WGA
WGA False things
More WGA False things
Re: Outage 10th Jan
« Reply #23 on: 11 January 2008, 20:39:44 »
My machine - no WGA
WGA False things
I know of both theses issues (its my job to ;))
The first only affects volume copies, which nobody should be using at home.
2nd was a simple glitch, and won't affect anything long term (the scope of it was very small).
Neither are a reason not to run automatic updates, as not putting on the security updates asap is dangerous and irresponsible.
Perhaps I should have said 'WGA for home users does not permenently give positives unless the licence has been breatched'
amigov6
Re: Outage 10th Jan
« Reply #24 on: 11 January 2008, 20:41:36 »
:-?Ditto  :-?
Re: Outage 10th Jan
« Reply #25 on: 11 January 2008, 20:49:19 »
:-?Ditto  :-?
The fact that you have managed to sign up here (so have an understanding of email and web) means you likely are IT literate enough to bluff your may through this setup ;)
theolodian
Re: Outage 10th Jan
« Reply #26 on: 11 January 2008, 21:42:42 »
:-?Ditto  :-?
