Author Topic: MAF Sensor Fault on P/FL V6 ??  (Read 1449 times)
24_Valve
  • Greater London
« on: 21 September 2010, 19:54:42 »
I diconnected the MAF sensor before last MOT retest to see if it would drop CO emissions. It actually doubled the CO content. I knew doing this would generate a fault Code 73 "Mass Air Flow Sensor Voltage Low" and it did.
I've reconnected the MAF plug & today reset the ECU (disconnected battery negative lead for 2 hours) to get rid of the fault code. Re-checked for codes & Code 73 still present? Does this indicate that my MAF sensor is faulty?? Also would Code 73 flash up if there's an air intake problem as opposed to sensor fault? thanks  :y
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
Re: MAF Sensor Fault on P/FL V6 ??
« Reply #1 on: 21 September 2010, 19:55:51 »
Disconnecting battery will do precisely bugger all (except make you reset windows and enter radio code).
You need a code reader to quickly clear codes...
« Reply #2 on: 21 September 2010, 19:58:20 »
Achieves less than the square root of nothing. The only way faults can be removed from stored memory are :
1) Reset by external device (tech 2 or other)
2a) On some faults - removing fault condition
2b) On some faults  2a + 20 or so "clean starts"
Disconnecting the battery will not clear faults at any time.
EDIT : Must type faster .. :(
« Last Edit: 21 September 2010, 19:59:04 by entwood »
24_Valve
  • Greater London
« Reply #3 on: 21 September 2010, 22:13:30 »
Thanks guy's, was surprised by the engine management light still remaining lit, briefly after starting, eventhough MAF plug reconnected?
but realise it might be a case of:
After replacing crankshaft sensor, Code 19 (that was showing with the engine running) just disappeared :y
« Last Edit: 21 September 2010, 22:14:25 by silvercross1 »
John-R
  • Liverpool
    • 2003 2.6 V6 CD
« Reply #4 on: 25 September 2010, 23:48:52 »
Had my battery disconnected as engine was rebuilt - long story on another posting. Can't get radio on (SAFE mode) and don't have passcard with radio code - neither do previous owners. Any idea how I can get the right code?
Also noticed passenger windows have lost one-touch function - have to keep finger on the button - again - any ideas??
Thanks.
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
davethediver
  • Blackburn, Lancs.
« Reply #5 on: 25 September 2010, 23:51:31 »
One touch covered in the how too section and as for the radio code try a PM to Dave DND in the electrical section :y
Here you go John just for the windows http://www.omegaowners.com/forum/YaBB.pl?num=1152602031
HTH
« Last Edit: 25 September 2010, 23:53:52 by davethediver »
P.A. Caron de Beaumarchais
Page created in 0.364 seconds with 20 queries.
