Author Topic: Radiator Fan problem? early V6 model  (Read 4340 times)
24_Valve
  • Greater London
Re: Radiator Fan problem? early V6 model
« Reply #15 on: 03 October 2010, 23:04:14 »
Thanks RobG, I will take your word on it, thought second from left was for K67 as shown in this diagram (identical to my layout) http://i863.photobucket.com/albums/ab197/philrich1064/Fan_test.jpg
The OOF diagram for V6 with a/c (mine) differs from my relay box... compare with pic above  :y
« Last Edit: 04 October 2010, 01:31:09 by silvercross1 »
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
24_Valve
  • Greater London
« Reply #16 on: 03 October 2010, 23:29:59 »
Thanks testomega, yours is same a FL layout which 2nd diagram shown for V6 models...http://www.omegaowners.com/forum/YaBB.pl?num=1176542235  but you seem to have K67 blue relay in second space? not black headlamp washer K97 relay as shown on diagram... but you're conjecture is right I do have A/C and therefore 3x Fans... So would agree that I should have same number of relays... except I don't have headlamp washers (your'e catera should have) so that would tie in with RobG's explaination  :y
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
« Reply #17 on: 04 October 2010, 03:24:21 »
I have no headlight washers  >:( ;D ;D ;)
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
Page created in 0.831 seconds with 16 queries.
