Author Topic: max 4,5k rpm and power loss  (Read 2846 times)
Welung666
Re: max 4,5k rpm and power loss
« Reply #15 on: 06 October 2010, 18:53:31 »
ålesund, norway :p
No where near local then ;D ;D ;D
This is for the 2.2 but similar enough for the 2.0 :y
http://www.omegaowners.com/forum/YaBB.pl?num=1269023974
RGrims
« Reply #16 on: 06 October 2010, 19:50:43 »
i just noticed that the thin air hose going out on the top left side on the engine was almost torn off, is that bad? :p hehe
« Reply #17 on: 06 October 2010, 19:58:28 »
Fix it whilst you're in a repairing mood :y
RGrims
« Reply #18 on: 12 October 2010, 17:39:54 »
hi again.
while changing the cam sensor i broke a bolt.. :p
not the one holding the cam sensor but the one below, going inside the engine, so i drilled in it to get the rest of the bolt out but it was stuck so i made a bigger hole so i could fit a new one and accidentally went through, is there something important in there?
i got the same codes btw. 38 and 92
« Last Edit: 12 October 2010, 17:40:15 by RGrims »
« Reply #19 on: 12 October 2010, 19:13:27 »
hi again.
 :o
any piccie ?
