Author Topic: Cambelt tensioner bolt snapped  (Read 7689 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Cambelt tensioner bolt snapped
« Reply #15 on: 11 April 2010, 22:31:56 »
Correct LD
Lifted from the Trade Club website.
Warranty
All GM parts are warranted a minimum of 12 months, unlimited mileage. All GM warranties are Europe-wide and cover both parts and labour. In the unlikely event that a GM parts develops a fault due to a material or manufacturing defect, simply call the service department of any Vauxhall or Opel dealer who will arrange to have the part replaced and fitted free of charge.
Certain parts enjoy a longer than twelve months warranty period as follows:
Clutches - 2 years, unlimited mileage
Exhausts - 2 years, unlimited mileage
Shock absorbers - 2 years, unlimited mileage
VXPRO remanufactured starter motors and alternators - 2 years/unlimited mileage
Batteries - 3 years, unlimited mileage
TuBy's new whipping boy.
« Reply #16 on: 11 April 2010, 22:42:48 »
Vx warranty on parts worthless anyway.  I bought a crank sensor from Vx dealer - packed up within 1 month - code 19 and car refused to start.  Removed it and fitted spare - started immediately.  Took it back and Vx say that I have to refit it and get my car into their Service Dept who will then check it and fit a new one FOC if found faulty.  Vx Dealer some 11 miles away and they will NOT pay costs of getting car into their Service Dept even if part faulty.  Not worth it for a £40 sensor - thieving barstewards!!!
  • Auckland
    • Mazda MPV
« Reply #17 on: 11 April 2010, 22:47:01 »
Is the bearing in the idler still free to turn?
I'm wondering whether the bearing siezed causing the centre to rotate and tighten the retaining bolt until it snapped :-/
« Reply #18 on: 12 April 2010, 08:10:44 »
Thats because your local dealer are shite.....Grose's I assume?
They would not take that stance with a trader......and they should not take that stance with you.....and Vx do not look for such evidence on returns either.
« Reply #19 on: 12 April 2010, 08:20:28 »
Agreed - altho good on getting bits all on TC or Trade prices.
Not Grose - Townsends @ Wellingborough.
Apparently this is a Vx initiative ????
« Reply #20 on: 12 April 2010, 08:44:26 »
What a load of old.....
Clearly not interested in customer service.
All they needed to do is fill in the warranty claim form stating a code 19 had been flagegd by the enw sensor......simples.
Vx then simply charge their supplier for a new part.
« Reply #21 on: 12 April 2010, 08:54:00 »
I've always found Grose's to be OK  :-/, but dont use them that often...
CyNick
  • Monmouthshire
  • Car is stuck in KIDDERMINSTER!!
« Reply #22 on: 12 April 2010, 14:26:14 »
Nick, when are going back to the car to take pics? I could meet you there if you want, see how far off it is for you, be able to decide then if it's one head or both :y
Thanks very much Lee  :y
This is the second time you have offered - I hope you didn't think me rude but I missed the first offer!   :-[
I'm going to post pics now, it's so difficult to get the camera into banks 3&4!
It looks to me as if 1&2 are pretty much in sync with each other, but 3&4 look slightly out, and seem way out with 1&2??
I'm pretty sure that when the cams stopped, the crank continued to turn, so will the damage depend on where the cams stopped?
Maybe a more experienced eye could give an opinion??
CyNick
  • Monmouthshire
« Reply #23 on: 12 April 2010, 14:31:25 »
Why are those photos so big? I uploaded 640x480, just like the 1st photos?
« Reply #24 on: 12 April 2010, 14:39:13 »
I'm a bit confused about cams 1 and 2 here
Why are marks "1" and "1", and then "2" and "2" in the same places on each pulley?
Should be in different places - differentiated by the ways the pulleys are fitted on the keyway...
« Reply #25 on: 12 April 2010, 14:39:14 »
Can you moved to TDC, and retake?
I may be having a blonde moment, but 1 looks to be way out of sync with 2?
« Reply #26 on: 12 April 2010, 14:39:44 »
Ah, exactly what I was trying to say, but better explained by you?
« Reply #27 on: 12 April 2010, 14:39:47 »
Agreed - see my post above, it's like they are both fitted in the same position on the cam keyways?
« Reply #28 on: 12 April 2010, 14:42:44 »
Also, TB -
A broken idler wouldn't cause that to happen, in itself -
The cam pulley would have to be physically taken off and re-fitted in that keyway position (unless the keyway on the cam has broken)...
My gut feeling is top end damage!
« Reply #29 on: 12 April 2010, 14:46:17 »
Also, TB -
Or the belt has slipped and it just so happens that's the orientation they ended up in?
Pages: 1 [2] 3 4  All   Go Up
