Author Topic: anyone a ''how to'' guide on lsd fitting  (Read 5098 times)
dervdoc
  • Co.Armagh, N.Ireland
  • super turbo diesels
« on: 15 September 2010, 19:34:16 »
im not after how to remove it from the car im looking of actually removing it from the diff casing
dervdoc
Re: anyone a ''how to'' guide on lsd fitting
« Reply #1 on: 15 September 2010, 21:09:13 »
have removed the two circlips from outersides wer shafts go in, so question is how do i get the highlighted bits in red out to get the diff out
« Reply #2 on: 16 September 2010, 02:04:08 »
Pm 2woody, he builds em. :y
2woody
  • Northumberland
« Reply #3 on: 16 September 2010, 11:23:44 »
why you taking it out ?
removing and replacing is not a problem - whereas changing bearings or building into a new casing is. That's when you need to be shimming it properly
dervdoc
« Reply #4 on: 16 September 2010, 15:23:22 »
its going into an omega housing, this is a senator lsd
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #5 on: 16 September 2010, 19:37:05 »
Hi
I'd be interested in this answer too, although mine is moving a Carlton LSD into an Omega casing.
Alan
dervdoc
« Reply #6 on: 13 October 2010, 17:46:48 »
i have the diff removed from the senator housing today,how is the preload determined on these diffs as as far as i see ya put it in, put the 2 bearing cups in an then circlips??? can any one say for sure that the splines on my td shafts will match that of the senator lsd,i aso want to know will my crown wheel fir the derv fit onto the senator lsd
david036
  • Lancashire
« Reply #7 on: 13 October 2010, 19:00:06 »
Sorry to hi-jack, but was it only the MV6 that came with the lsd?
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
veesta
« Reply #8 on: 13 October 2010, 19:37:55 »
Depends on the market, but i have 2.2 automatic with lsd.
It was common to have those in Finland and in Scandinavia in general.
Helps a bit on the snow. :) Don't know about the UK versions if they have it or not.
2woody
  • Northumberland
« Reply #9 on: 14 October 2010, 12:04:03 »
in the UK, no Omega B's had LSD as standard.
Police cars often (but not always) had them retrofitted by MSD before delivery
and I suspect it was available as a very special option on a new car, but have never seen one.
your diesel crownwheel will fit the Senator diff carrier.
your driveshafts will fit into the Senator diff internals ( provided it's not off a Senator A )
the pre-load and half of the mesh is determined by the thickness of the circlips - they're selective. Get'em wrong and it'll howl enough to wake the dead, before coming through the diff casing.
« Last Edit: 14 October 2010, 12:04:31 by 1417_stuart_grange »
dervdoc
« Reply #10 on: 14 October 2010, 22:10:35 »
senator B diff i think? wud the part number on the crown wheel tell me if it was of a senator a, or is my best option to pop a shaft of and try it,
i had a suspision it was the thinckness of the circlips that sets preload as i didnt see any shims when i removed it,
so what should the preload be? i know how to blue die the crown wheel to check the back lash but how do i adjust it if i find she aint showing properly on the crown wheel?
« Last Edit: 14 October 2010, 22:12:27 by dervdoc »
2woody
  • Northumberland
« Reply #11 on: 15 October 2010, 09:07:17 »
backlash is changed by fitting thicker circlip at one side and thinner one at the other and vice versa.
pre-load is changed by fitting thicker or thinner circlip to just one side.
Senator A diff is completely different - no rubber propshaft coupling and a bolt-on flange for the driveshafts.
the full instructions are in TiS somewhere
« Last Edit: 15 October 2010, 09:07:48 by 1417_stuart_grange »
dervdoc
« Reply #12 on: 15 October 2010, 16:17:38 »
right i get ya now thanks for ur help 2woody, very much appreciated,will i be ok to use the bearings and bearing cups from the senator diff? anyone have an idea where to get diff seals from as vx are looking near £50 for just the two drive shaft seals!!!
« Last Edit: 15 October 2010, 16:21:45 by dervdoc »
dervdoc
« Reply #13 on: 15 October 2010, 16:19:40 »
and also where to find different thickness circlips if i need them? :D
2woody
  • Northumberland
« Reply #14 on: 16 October 2010, 21:40:44 »
i get seals from local beaing supplier - jus measure your old ones.
circlips are dealer only
