Author Topic: Having trouble removing joint on steering idler!  (Read 1221 times)
El_Swervo
  • Farnborough Hants
    • Omega estate, CDX 2.6
« on: 16 October 2010, 16:41:58 »
Hello All,
The second current problem with my Omega right now is a very worn out steering idler.
I have bought a replacement and tried to remove the old unit. However, It wont come apart. I have tried 3 different ball joint type splitters, the hammer/prybar method and some brute force and ignorance, none of which have done the job.
Will I have to remove the whole lot and do it on a bench or does anybody have a good tip for stubborn steering idlers? I have looked on the forum for an answer to no avail, if there is a thread could someone put me in the right place!
Varche
  • middle of Andalucia
    • Golf Estate
Re: Having trouble removing joint on steering idler!
« Reply #1 on: 16 October 2010, 18:12:27 »
You are not alone with this problem.
When I did mine I applied plus gas (not useless WD40) and then used the time honoured method of two hammers. Hitting both sides simulaneously. I nearly gave up about a thousand times and then bingo it came free. Suggest you try the same.
« Reply #2 on: 16 October 2010, 18:34:33 »
Hello All,
Have you looked at this? :-? :y
http://www.omegaowners.com/forum/YaBB.pl?num=1268602974
« Reply #3 on: 16 October 2010, 19:06:22 »
Using the method in the guide (aka, the DTM Method), its relative easy :y
2woody
  • Northumberland
« Reply #4 on: 16 October 2010, 21:32:08 »
the secret is a light hammer - it's the sharpness of the shock that does the trick, rather than the weight of the blow
El_Swervo
  • Farnborough Hants
« Reply #5 on: 17 October 2010, 14:21:55 »
Thanks Men!
I will have a go at this asap, I gave up first time after two hours! now every bump,(read pot hole!), and speed hump is cringeworthy. :o
Will post results and thanks post job!
Thank you all again
Page created in 0.033 seconds with 20 queries.
