Author Topic: Not starting first time in the morning  (Read 4557 times)
tango
  • brum
Re: Not starting first time in the morning
« Reply #15 on: 18 October 2010, 21:35:40 »
100% Crank sensor. (ok 99% but thats where the smart money is)  not expensive and easy to change without even removing the wheels. EXACT same on mine, fixed.
will give it a try as ive got a car here wich im breaking at mo so have loads of bits
wich one is the crank sensor
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #16 on: 19 October 2010, 23:15:47 »
my comment was aimed at JayJay29, the originator of the thread - suggest you might want to start your own, but while you're here, the cranksensor is located next to the oil filter housing (on a V at any rate)  - but I wouldn't recommend changing it for another second hand one - unless you can verify its integrity
jayjay29
  • Cheshire
« Reply #17 on: 21 October 2010, 21:54:56 »
Hi guys seen to have sorted this its started first time all week.
After doing the oil change a couple of weeks ago i chanced the crank sensor had fouled with some oil during filter removal!
Took the crank sensor off it had oil all over it gave it a good clean put it back and she has started first time ever since. So until it does it again i will hold back on repacing the sensor.
Cheers Jay
Jay
