Author Topic: Oil Sump plug Shredded  (Read 7836 times)
RexNoctis
  • Leicester
Re: Oil Sump plug Shredded
« Reply #45 on: 11 October 2010, 11:04:29 »
Yup, I changed the oil on my tractor and found hard bits of metal in the runoff. Wasn't until I tried to tighten the sump plug back up that I realized what they were!
I made a temporary repair with liquid metal as i needed the car running and I knew I would need a new sump anyway. I was hoping the sump pan could be unbolted and slide around the subframe, now I know better. :-(
Will have to spend some proper money, may as well get the sump and wishbones replaced at the same time, roll on payday!
Omegatoy
  • UK
« Reply #46 on: 11 October 2010, 19:03:10 »
if thats the standard sump lug, no need to replace the sump, just drill it to the next size up and retap, i think if i remember correctly its a peugoet sump plug that is the next size up, takes just twenty mins to do as well, changing the sump is a pita job
« Reply #47 on: 11 October 2010, 19:42:31 »
Nope, it still strips.  Helicoil is only sensible option on the BMW sump
Omegatoy
  • UK
« Reply #48 on: 11 October 2010, 19:58:31 »
lol your just a grumpy gorilla!!! my plug is still the original,
even though i welded a 19mm nut to it to make the changing of oil easier when i first got the car!!! :y
« Last Edit: 12 October 2010, 06:26:22 by Omegatoy »
osealy
  • dublin
« Reply #49 on: 11 October 2010, 22:15:46 »
Use a pump! The filter should catch the lumps of metal.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #50 on: 24 October 2010, 17:40:42 »
Mine hasn't, see my earlier post. ::) ::) ::)
osealy
  • dublin
« Reply #51 on: 24 October 2010, 19:14:37 »
PUMP. Oil +filter change 20 mins start-finish & no crawling
Pages: 1 2 3 [4]  All   Go Up
