Author Topic: Where's the Vaccumhose, MV6 -95  (Read 1473 times)
EXD
« on: 24 October 2010, 16:12:17 »
Hello
I'm putting my engine together again, and I'm almost done.
However, there's a vaccumhose missing...somewhere!?
I'm afraid it maight be somewhere behind the engine?!
Does anyone know which hose should go there???
Here's some pictures of the connection:
Varche
  • middle of Andalucia
    • Golf Estate
Re: Where's the Vaccumhose, MV6 -95
« Reply #1 on: 24 October 2010, 16:31:29 »
Hi
I can't really tell from the photos.
Is one the curved hose in photo#1  ?
If the car is an automatic then there is also a gearbox breather pipe in the area at the back of the plenum. It doesn't connect to anything. It is of course bigger diameter than a vac hose. maybe half inch ext diameter.
EXD
« Reply #2 on: 24 October 2010, 16:46:54 »
Its the black small pipe, wich the red arrow is pointing at.
Here's another picture, I've circle'ed the pipe:
http://www.ladda-upp.com/bilder/42100/opel-omega-mv6-233
What should be connected to it??
des.allen
  • Preston lancs
  • 2000 2.5 v6 elite nearly LPG
« Reply #3 on: 24 October 2010, 16:55:14 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204  HTH Look in the maintenance section index and click v6 engine bay vaccum pipes :y
« Last Edit: 24 October 2010, 17:03:24 by des.allen »
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #4 on: 24 October 2010, 17:18:10 »
It's been a while since i had my plenum off, but IIRC, there is a vac hose with a curve in it that goes round to the bottom right hand corner of your last picture, towards the ICV, and IIRC it actually connects to the large hose coming off the ICV, on the underside, so it isn't immediately apparent.
TC and BnQ Trade holder.
EXD
« Reply #5 on: 24 October 2010, 17:41:47 »
Aha, ok.
I think I connected that hose from ICV to some "valve" or something on the fuelrail!
Then the next question is, what should be connected to the round thing on the fuelrail??
Welung666
« Reply #6 on: 24 October 2010, 18:48:31 »
Aha, ok.
The vacuum hose for the one in your picture runs along the cable tray and round to that valve. If it is connected to the pressure regulator then re-connect it to the valve. The pipe on the pressure regulator comes from the pipe connecting the IACV to the inlet trunks at the front. :y
EXD
« Reply #7 on: 24 October 2010, 19:42:32 »
Thanks alot for the help, you're a lifesaviour.
I will continue the reassembly tomorrow...
EXD
« Reply #8 on: 25 October 2010, 13:48:29 »
Shit, I need some more info on this.
I've been out now but I have'nt seen any vaccum hose hanging loose...exactly what is IACV??
O'boy this really is a maze  :P
EXD
« Reply #9 on: 25 October 2010, 14:50:04 »
I FOUND IT!!!
It was hidden behind the engine!  ::)
Now there's only two more screws then I can finally see if the reassembly was a succes or a failure.
If the engine starts, later, it will be the first time since may.
I miss my car... :)
Page created in 0.034 seconds with 20 queries.
