Author Topic: headlight cover  (Read 2778 times)
manolo
headlight cover
« on: 27 October 2010, 10:56:48 »
is it possibly to replace only plastic headlight cover on omega b 2002
 [smiley=vrolijk_26.gif]
Re: headlight cover
« Reply #1 on: 27 October 2010, 11:09:05 »
you can't buy the lens separately, but it is possible to separate the lens from the headlight by carefully easing it away and gently slicing through the black goo that holds them together. See the guide re replacing the broken headlight adjusters with an ally replacement.  :y
manolo
Re: headlight cover
« Reply #2 on: 20 June 2015, 20:08:56 »
I am looking for something like this for Omega 99-03 with xenon
http://m.ebay.com/itm/291410307156?nav=SEARCH
« Last Edit: 20 June 2015, 20:14:59 by manolo »
Re: headlight cover
« Reply #3 on: 20 June 2015, 20:26:23 »
Is the old one cracked or damaged? If just cloudy they can be polished up with something like the 3M kit  :y
manolo
Re: headlight cover
« Reply #4 on: 20 June 2015, 20:44:12 »
I polished them twice and it is OK for short time, probablly because no UV protection. Now I have to change adjusers so consider  to change plastic cover to
Re: headlight cover
« Reply #5 on: 20 June 2015, 22:34:13 »
What you linked to are stone chip guards rather than replacement lenses... Either new GM or Depo/Valeo etc pattern ones for new choice or second hand for budget :y
Re: headlight cover
« Reply #6 on: 21 June 2015, 09:47:50 »
Clip on protectors wouldn't stop the UV damage?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: headlight cover
« Reply #7 on: 21 June 2015, 09:57:26 »
Did I see a post some time ago about an anti uv spray . May factor 50 might help :D
