Author Topic: Ignition key jamming.  (Read 3014 times)
shyboy
  • Southport, merseyside.
    • Mazda 6
Re: Ignition key jamming.
« Reply #15 on: 28 October 2010, 13:08:59 »
I've solved the immediate problem with cycle oil but can feel a slight stiffness in the key operation which will need attention ASAP.
Not having access to compressed air, Kevin, I used an ordinary cycle pump with someone pumping it behind me and this seemed to blow sufficient oil into the mechanism.
Shall run for a day or two without the cowls etc. in place, and see what happens.
Thanks again for all the help.
« Reply #16 on: 28 October 2010, 14:46:30 »
Yep, see how it goes, but if it still feels a little notchy as you initially turn the key I would pop the barrel out and check it.
