Pages: 1 2 [3]  All   Go Down
Author Topic: Fault codes 43 and 81 - help/parts needed  (Read 8237 times)
Vulpine
  • Kent UK
  • Omega 2.5TD The Vegmega!!
    • Omega 2.5TD '97
Re: Fault codes 43 and 81 - help/parts needed
« Reply #30 on: 28 August 2010, 18:50:45 »
Have changed clutch today (see another post for details) and code 19 has gone.   :D
All i did was clean all the iron filings of the end.
The air gap on mine was 0.42mm.
So the search goes on for a used or new #4 injector......
Admin edit
Welung666
« Reply #31 on: 28 August 2010, 19:07:19 »
Have you tried cleaning the injector by removing it and stripping it? There is a great little guide in the maintenance section.
« Last Edit: 28 August 2010, 19:07:36 by Welung666 »
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #32 on: 28 August 2010, 19:15:14 »
Yes done that and it was o so clean already lol.
Look like the sensor can be removed but didnt try that yet.
Also, I only had one washer inside the injector but the guide shows 2off?
Admin edit
Welung666
« Reply #33 on: 28 August 2010, 19:28:09 »
Has anyone seen tigers_gonads on recently? He was breaking a TD but hasn't been on since the 17th of August. Worth a PM maybe :y
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #34 on: 02 September 2010, 19:47:56 »
RESULT!!!  ;D
All fixed - replaced number four injector froma local scrap yard and all is go again. I am sure it was that VPower fuel that killed it.  >:(
Only cost £40 - plus the scrappies has loads of Omegas and at least 2off good 2.5td engines. If you need anything give Shaun at call @ Ashford Vauxhall Spares and said I sent you on 01233 820135 Ashford, Kent TN26 3JP (http://www.ashfordvauxhallspares.co.uk/)
Thanks to everyone for your help, much appreciated.  :y
Jon Fox
Admin edit
Kneepad
  • West Scotland
« Reply #35 on: 02 September 2010, 21:23:35 »
Well done Vulpine. Admire your perseverance.  :y
« Last Edit: 02 September 2010, 21:24:06 by Kneepad »
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #36 on: 31 October 2010, 09:26:43 »
BTW everyone, i have a spare crank sensor for sale if anyone needs one - PM me etc
Admin edit
Pages: 1 2 [3]  All   Go Up
