Author Topic: Headlamp wattage  (Read 1399 times)
GaryBC
  • Egham, Surrey
Headlamp wattage
« on: 03 November 2010, 09:48:38 »
Hi guys
I'm running common or garden H1 Halogen filaments and was wondering if I'd get any significant improvement to the light output if I were to change from 55w to 65w in the dipped beams.
On the downside, would the lamp enclosures be able to cope with extra heat? And would the additional current draw mess up the electronics?
Cheers,
Gaz
Re: Headlamp wattage
« Reply #1 on: 03 November 2010, 09:59:49 »
Fit "Osram Nightbreakers", big improvement :y
Welung666
« Reply #2 on: 03 November 2010, 10:01:13 »
Seconded. Anything brighter that standard bulbs are illegal for road use anyway.
GaryBC
  • Egham, Surrey
« Reply #3 on: 03 November 2010, 10:17:04 »
Ta. Are they generally available - eg Halfords?
Welung666
« Reply #4 on: 03 November 2010, 10:18:56 »
eGay ;) cheaper ;D
GaryBC
  • Egham, Surrey
« Reply #5 on: 08 November 2010, 16:19:44 »
I picked a pair up online for about £17 - they're brilliant (sorry about the pun)! Thanks for the suggestion.
One thing that changing to decent headlights has highlighted (sorry again!) is that my offside beam seems to be set slightly lower than the nearside one.
I've looked for the adjuster but can't find it. How can I tweak it up slightly?
« Reply #6 on: 08 November 2010, 16:24:59 »
There's a clue on top of the headlight  ;) .... it says 'for adjustment see owner's manual'   :y one is for up/down t'other is left/right
Marc Taylor
  • Essex
« Reply #7 on: 08 November 2010, 17:24:14 »
I have used higher wattage bulbs upto 130w and no difference at all.  At the moment im using the halfords excellence bulbs (only as they were bogof) and noticed a decent improvement but next time will be going for the nightbreakers or hid kit
GaryBC
  • Egham, Surrey
« Reply #8 on: 14 November 2010, 16:51:43 »
There's a clue on top of the headligh;) .... it says 'for adjustment see owner's manual'   :y one is for up/down t'other is left/right
Oh yeah!! D'oh!! (In my defence, I was looking in the engine bay at the rear of the lamp assembly!)
I located the adjusters as ringed in the photo but, when I turn them, they just rotate uselessly! Am I missing something else that is blindingly obvious?
GaryBC
  • Egham, Surrey
« Reply #9 on: 14 November 2010, 16:52:45 »
Defo recommend them! They've made a noticeable improvement.
« Reply #10 on: 14 November 2010, 16:53:52 »
If memory serves they are a VERY fine thread and take many revolutions to achieve any large movement.
GaryBC
  • Egham, Surrey
« Reply #11 on: 15 November 2010, 10:52:40 »
In that case, I'll have another go. Don't suppose you can remember which one is up/down and which is left/right?
« Reply #12 on: 15 November 2010, 10:59:11 »
no, but there's only a choice of 2  ;)
