Author Topic: depressurising air con system for engine removal  (Read 3758 times)
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: depressurising air con system for engine removal
« Reply #15 on: 01 November 2010, 22:52:50 »
o.k in all honesty if you call someone they may come and depressurise the system for you free of charge as they get your gas, if not well the choice is then your's but in general a cars air con in one year will lose upto 8percent of its fill through seepage which the government wants nothing to do with so if you wait 12 yrs you're good to go!!!
Warning: Dates in Calendar are closer than they appear.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #16 on: 01 November 2010, 22:55:07 »
Gentlemen Please.... carry it on after school behind the bike sheds  :-*
Cheers :y
« Reply #17 on: 01 November 2010, 23:01:56 »
Undo the shreader (sp?) valve slightly until you can hear the gas escape then make yourself a cup of tea.
Dont inhale the gas and dont let it touch your skin.
Obviously it is not advised, and obviously harmful to the planet, just like most Air-Con systems which leak anyway.
Thats the way I always do it.
Thats illegal mate  >:( and not helpful advice to the Op on an open forum.
I'm well aware of that  :y
Doesn't stop the likes of Kwik-Fit etc topping up your system just for it to leak into the atmosphere over the next few months, then further commit crime by charging £40 for the benefit::)
Maybe but the Op has asked for advice and to give him advice thats illegal is i feel not what OOFs about.
OK, I appreciate what you are saying.
The wording of the OP's question speaks volumes, but as you evidently missed it, I'll look like the bad guy  ::)
BY THE WAY KIDS, SNIFFING GLUE IS BAD!  NOBODY DRINK, NOBODY SMOKE, NOBODY PULL LEGS OFF SPIDERS.  IT'S NAUGHTY!
No I didn't mate - thats why I mentioned using a scrap yard.
There's also no need to shout and throw your toys out of the pram!!
 ::) When offering good advice like not sniffing glue, it's good to shout.  :y
Yep agree with your comment re sniffing glue.  Regarding drinking, smoking and pulling legs off spiders, thats not illegal (yet thank god) -though what any of this has got to do with air con escapes me.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #18 on: 01 November 2010, 23:21:39 »
OP - The ONLY way you can de-pressurize the system is to take it to a qualified Air-Con engineer who will safely remove the gas and not kill any ants, or something.
Never ever EVER remove the gas yourself else ants and things will die, and thats really really bad. Furthermore, you will receive a minimum of life in prison, sharing a cell with George Michael resulting in a poorly bum.
HTH
« Reply #19 on: 01 November 2010, 23:26:23 »
HTH
Peti
  • 1994, V6, 2,5 l, aircon
« Reply #20 on: 14 November 2010, 07:30:14 »
Hi you guys
I'm wondering if I can take out the air distribution unit WITHOUT discharging the air con system.
I'd , of course , disconnect wiring connectors and vacuum hoses, and then unscrew retaining bolts.....but.... do I really have to open air con ,as it's written in Haynes ?
faced with removing an engine from a v6 with air conditioning i wonder if anyone can advise on the practicalities of depressurising the air con system.
i *think* i'm right in saying you should get a specialist in to do that job for you, soooo instead of awaiting the replies of 'you have to get a specialist in' let me ask the question in other words...
if you got a specialist in to depressurise your air con system because you were removing a v6 engine with air con from an omega, what would that specialist have to do, and how would that specialist advise you to do it, if you were qualified. am i making sense? you can read between the lines i'm sure.
 ;D :y
gsizoli
  • Hungary
« Reply #21 on: 14 November 2010, 08:07:39 »
In case of V6 no need to depressurising the system for engine removal/install. You can remove the engine if you have a helper who will move away the compressor carefully when you lift the engine. I've already done it.
Peti
« Reply #22 on: 14 November 2010, 08:25:06 »
Sorry, but I only want to remove the AIR DISTRIBUTION unit, under the facia....the whole thing as one single unit.
As far as I can see it's held in position by 3 bolts : 2 from behind, in the engine compartment and 1 inside, on the upper edge.
Peti
« Reply #23 on: 17 November 2010, 07:45:59 »
...please help me....so can I take out the AIR DISTRIBUTION unit WITHOUT discharging the air con system.
Can it be simply pulled off with the air con parts left in their place ?
mantahatch
« Reply #24 on: 17 November 2010, 10:23:19 »
After I had my A/C system depressurised I was told that it was possible to unbolt the compressor and swing it to one side to get the engine out.
I haven't tried it myself but I would think if anyone knew the answer then Darth Vader would :-/
Indeed it is possible and even desirable to leave the air con pump and power steering pump in the car when removing the V6. That is exactly what I did when changing the engine on mum's car.
Peti
« Reply #25 on: 17 November 2010, 12:00:05 »
So....again....can anyone help me answer this :
Can can I take out the AIR DISTRIBUTION unit, i.e. the big black plastic thing behind the radio WITHOUT discharging the air con system ?
Sorry for being so fanatic on this topic ....:)
Peti
« Reply #26 on: 17 November 2010, 16:32:38 »
Please.......
Page created in 0.036 seconds with 20 queries.
