Author Topic: 99T 3.0 Elite Estate. Various Problems, Connected?  (Read 4266 times)
Paul T.
  • Wilmslow
« on: 03 December 2010, 02:03:33 »
Evenin' everyone.
I've a list of faults that I have listed below in the hope that they are all (or most) connected in some way.
Heater/Climate: Blows hot on drivers side and freezing on passenger side.
Airbag light: Stays on all the time.
Alarm: Goes off a few minutes after arming, so having to leave car unlocked on the road.
Gearbox: Long story. Started jumping and clunking a few years ago and then limp mode. Turn off, start back up and out of limp mode but still jump/clunk.
Had new switch fitted (2 yrs ago) at main dealers to cure problem (£350) but it failed to remedy the problems. Got refund (not sure if they removed switch because I think they may have binned my original one).
Had ATF and filter changed last month and slight improvement but gearbox is still misbehaving. Sometimes the clunk feels like huge hammer has whacked the car from underneath.
Had car from 1yr old, 17k miles (ex-vauxhall). Full VXSH until last service by a local garage. Car has now covered 98k.
Some of the problems will be my fault. Let her stand for 2yrs and only ran her 10 times in that time due to crank sensor fault (now fixed) so couldn't get started a lot of the time and therefore dampness got to the interior.
She's a good old bird who's been a grand servant and in great nick for her age and I don't want to lose her if I can help it.
Any help greatly appreciated.
Many thanks.
Paul.
« Last Edit: 03 December 2010, 02:05:48 by Paul_Tansey »
Re: 99T 3.0 Elite Estate. Various Problems, Connected?
« Reply #1 on: 03 December 2010, 09:14:19 »
Not related...
heater - check servo arm for passenger blend flap
airbag - needs checking with proper diags
alarm - bonnet switch is common. Unplug, then see what happens
gearbox - could be anything, what engine is it bolted to?
Kneepad
  • West Scotland
« Reply #2 on: 03 December 2010, 09:14:50 »
This should sort your heater problem:
http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
Check your bonnet switch and make sure it is seating properly, one of the most common reasons for the alarm activating.
Paul T.
  • Wilmslow
« Reply #3 on: 03 December 2010, 15:53:50 »
Not related...
Thanks for the info, sounds promising.
Engine number from VX Car Pass = X30XE /08338812.
Cheers,
Paul.
« Last Edit: 03 December 2010, 15:56:20 by Paul_Tansey »
Paul T.
  • Wilmslow
« Reply #4 on: 03 December 2010, 15:55:17 »
Thanks for the info, looks to be the likely cause.
Cheers,
Paul.
« Reply #5 on: 03 December 2010, 16:31:33 »
The 3.0l isn't known for eating its AR35 autobox, so check fluid level is perfect, then you are in the realms of looking further.
A full description of exacly when it happens will help the experts here offer advice on what could be causing it...
trem
« Reply #6 on: 03 December 2010, 16:53:33 »
when my selector switched oppsed up earlier in the week the gearbox was bangin clunkin from 1st to 3rd, and makin some strange noises, try cleanin it out, its not that hard of a job just one side (passenger side) up high and do it when exhaust is cold, watch out for sharp bits on exhaust im still wearin the scar's.
Good luck and hope you get it all sorted soon
PS look for auto box problems  in general help, i started a topic
Paul T.
  • Wilmslow
« Reply #7 on: 03 December 2010, 17:29:28 »
Thanks.
The fluid level should be spot on.This and the filter was changed a month ago along with a good clean out (nothing too bad just the usual grey sludge).
If the car is ever going to misbehave it is when "sport" is selected. In this case, if floored it will pick up okay but will sometimes redline and fail to change up from 3-4th or 4-5th unless you take your foot off the gas. Again in sport mode a clunk/jump can be felt between 2-3rd with the engine spinning in limbo until the gear is found and then "WHACK".
Also in sport, gentle deceleration when approaching lights/junction can result in a huge whack when downchanging from 3-2nd.
I trust the guys who did the ATF and filter change and the car behaves pretty much the same as before the change except the changes are smoother.
Took her out this morning (not in sport), freezing and she was as good as gold even though she was hard driven on the salted empty bypass.
Any clues would be great.
Thanks.
Paul.
« Last Edit: 03 December 2010, 17:31:06 by Paul_Tansey »
« Reply #8 on: 03 December 2010, 17:31:42 »
Sounds like a dodgy 2-3 solenoid in the box. Easy enough to change with the sump off
Paul T.
  • Wilmslow
« Reply #9 on: 03 December 2010, 17:36:46 »
Thanks for that.
I'm sure the box is clean after the ATF/filter change (the guys who did this are very good). Maybe the selector switch you talk about is the same switch my VX dealer put on the car a few years ago without success?
Thanks for the replies everyone.  :y
Paul T.
  • Wilmslow
« Reply #10 on: 03 December 2010, 17:38:24 »
Thanks Rob. Any idea of the cost of the part?
« Reply #11 on: 03 December 2010, 17:40:57 »
trem
« Reply #12 on: 03 December 2010, 17:45:24 »
after another read sonds like a completely different fault to wat i had
Paul T.
  • Wilmslow
« Reply #13 on: 04 December 2010, 21:33:11 »
Thanks The Boy & Kneepad. Disconnected the bonnet switch and the alarm is no longer misbehaving. I'll have a look see if it is seated properly tomorrow.  :y
Central locking has gone out of sync today though. N/S front door permanently locked at the moment.  ::) Any ideas again please.  :-[
« Last Edit: 04 December 2010, 21:34:19 by Paul_Tansey »
Kneepad
  • West Scotland
« Reply #14 on: 05 December 2010, 00:27:12 »
Glad to hear you silenced the alarm.   :y
Try  a re-sync with the key in, ign on, press lock then unlock on the fob.
Failing that, I suspect the central locking solenoid in the drivers door has failed.  :(
