Author Topic: Mix Up of Problems  (Read 3483 times)
mathewst
  • Split, Croatia
    • v40
Re: Mix Up of Problems
« Reply #15 on: 06 December 2010, 17:21:09 »
Marke that sound like the coolant level sensor is dead.
You can replace only the whole coolant tank (around 30 pounds according to other members was the price of the tank from the dealers)
Marc Taylor
  • Essex
« Reply #16 on: 06 December 2010, 19:08:08 »
Where is the coolant rail and what does it look like.  Is there an easy way of working behind and around the gearbox to piping??? I tried taking the scuttle off but failed on getting the wipers off
i tried that yesterday Matthewst and because its trickling down its hard to pinpoint, I think iv narrowed it down to either the piping that runs from the bottom of the rad to the back of the engine, the pipes coming out of the water pump or the water pump.  Im assuming the pump is ok as the car is not overheating at all and still getting heating although feels a touch cooler when at lights or crawling than when travelling at normal speeds
Marc Taylor
  • Essex
« Reply #17 on: 06 December 2010, 19:41:35 »
could my troubles be anything to do with the thermostat? it was new on in may but could it be sticking or something and allowing a flow hence more pressure and leaking???
just an idea
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #18 on: 07 December 2010, 12:06:58 »
Hiya Marc where are you in essex. I'm near southend, if you're near and you would like another pair of eyes , shout out!!!
Marc Taylor
  • Essex
« Reply #19 on: 07 December 2010, 23:19:41 »
Hi sandune, i live in tilbury.  I might need to call on you but iv managed to swap my job tomorrow to a later start so i have a few hours in the morning to take the inlet off and see how what i can do
Page created in 0.026 seconds with 20 queries.
