Author Topic: Camber?  (Read 2236 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Camber?
« Reply #15 on: 09 December 2010, 10:52:04 »
browns do rear and back from £45-£48, £25 extra if they cannot undo the adjuster. but if going to get it done would soon before the tax increase come's in,,, the one down here are fine even watch them doing it and see for your self.
Solar charger fitted.
If not Broke dont fix it..
Abiton
Re: Camber?
« Reply #16 on: 09 December 2010, 11:52:10 »
No point in getting it set up, or just checked, anywhere, until you're reasonably confident that there aren't any problems with wishbone bushes etc.
If there are such problems, even a perfect set-up on the best machine will translate into who-knows-what when actually driving down the road.
I'd expect WIM/Tony to check such things before starting any set-up, but many other places are likely to just charge in there and start measuring/tweaking.
Omega_Dan
Re: Camber?
« Reply #17 on: 10 December 2010, 10:02:22 »
Thanks for all the advise gents! going to get the car up in the air tomorrow and have a look at the possible causes mentioned. Will check on a true flat surface with a sprit level also!
cheers :y
