Author Topic: Engine Stalling ?  (Read 1157 times)
DeRangeRC
  • The Peak District (mostly)
  • Taking it on one job at a time.
Engine Stalling ?
« on: 14 December 2010, 23:42:21 »
My first post so first of all hello to all and thanks in advance for any help you may be able to give.
Straight down to business I am afraid.....
Bought my very first Omega on Saturday (1999 T 2.0 GLS auto) and so far I love it, large, comfortable and loving the drive. Now I didnt pay a kings ransom for it so I expect a few little niggles from an 11 year old car which I am sure i will be sorting in the coming months.
BUT when I drove home tonight I came to reverse into the street and it stalled when i moved from drive to reverse... started back up and reversed into my space, stopped and back to D and same thing happened! left it an hour and went out again and when I pulled up i put it into N and it stalled again. :(
Drive home a couple hours later and no probs at all ?  :-?
Any ideas guys ? Sorry if this is a regular problem but have not had time to trawl through and it says I cant search too often !!
Looking forward to any bright ideas.
Rob
If its rusty cut it out.
If its dry, oil it.
If its dull, shine it.
If its stuck.......smack it with a hammer of course !!
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: Engine Stalling ?
« Reply #1 on: 15 December 2010, 00:14:45 »
it could be the idle valve  may be worth cleaning with carb cleaner :y
vauxfan2k
  • Western Isles
« Reply #2 on: 15 December 2010, 00:15:26 »
there is an idle control valve located under the air intake pipe going into the inlet manifold, it probably needs a good clean out and refitting, brake cleaner or the likes will do.
its a fairly easy job to do  :y
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #3 on: 15 December 2010, 00:16:27 »
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #4 on: 15 December 2010, 06:01:10 »
check spark plugs, may be originals still in.
Solar charger fitted.
If not Broke dont fix it..
DeRangeRC
« Reply #5 on: 15 December 2010, 10:43:41 »
have a look here http://www.omegaowners.com/forum/YaBB.pl?num=1194007453
See I knew there would be a previous thread somewhere, Cheers Millwall for finding it out.  :y
Ok with all the advice I reckon a full service and at the same time follow the above and see if we find the little gremlin !!
Unfortunately I cant find a receipt for a full cam belt kit change either so perhaps put that on the cards too.
Anybody know an approx cost on how much to have the belt done ?
Rob
If its dry, oil it.
« Reply #6 on: 15 December 2010, 11:08:34 »
Check the crank case breathers are clear while you're at it.
Also, change the water pump with the cam belt. It's driven by the cam belt so pump failure can be catastrophic.
Page created in 0.044 seconds with 20 queries.
