Author Topic: clutch  (Read 2495 times)
ajay_2.2dti
clutch
« on: 22 December 2010, 15:37:00 »
 ive got vibrations at low revs when driving, i think its clutch related, im geting clutch drag, is it easy to change a clutch on omega ? :-?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: clutch
« Reply #1 on: 22 December 2010, 15:44:10 »
...im geting clutch drag...
Is that the clutch slipping or hard to get into gear?
It's gotta be worth trying to bleed or adjust (assuming hydraulic but maybe mechanical?) the pedal before condemning the clutch...
Re: clutch
« Reply #2 on: 22 December 2010, 15:47:32 »
Hi Ajay,
A bit more information on your symptoms is required to confirm your diagnosis, but in order to answer your question, a clutch change is not difficult, requires no specialist kit, and can be done by a competent DIY home mechanic.
I've written a guide that describes the process, and it's available to view at:
http://www.omegaowners.com/forum/YaBB.pl?num=1221078473
Kind regards,
James
(Post modified by myself. Reason: To rectify quote).
« Last Edit: 22 December 2010, 15:49:22 by JamesV6CDX »
ajay_2.2dti
Re: clutch
« Reply #3 on: 23 December 2010, 14:24:33 »
its not clutch slipping, its sometimes hard to find 1st gear, i would like to replace the clutch but just worried about the flywheel, bcoz its really expensive lol plus its freezin out side  ;D
Welung666
Re: clutch
« Reply #4 on: 23 December 2010, 16:07:35 »
How high up is the biting point on the clutch pedal? It should be a little under the halfway point. Any rattles with your foot off the clutch pedal when in neutral and the engine running? Any difference in noises between starting the car with your foot down on the clutch and starting it without your foot on the clutch?
Re: clutch
« Reply #5 on: 23 December 2010, 16:26:32 »
If it's dragging, also worth investigating the hydraulic circuit. Give it a few pumps of the pedal, engage first and keep the pedal down. Does it start to drag after a while?
Might also be worth bleeding it?
Regarding juddering, is this as you are pulling away or when driving in-gear with the clutch released?
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: clutch
« Reply #6 on: 23 December 2010, 17:26:02 »
do you know when the gear box oil was changed as had this type of problem last year and it was the oil gone week, changed the oil and it was fine, gears moved fine again and no drag. :)
« Last Edit: 23 December 2010, 17:26:18 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
ajay_2.2dti
Re: clutch
« Reply #7 on: 23 December 2010, 19:09:42 »
i know i do have a problem with the gearbox oil, the seal on top of the gearbox is worn out bcoz its spiting out with gearbox oil , but i do keep this topd up.
 kevin - after while driving my car as i pull away frm the lights and release my clutch in 1st gear the whole front of the car vibrates badly, and its better to wheel spin off.
welung666- my biting point fine, no rattles, i do start my
 car up with the clutch down coz its easier to turn ova i think.
 but today ive notice when i drive at low revs at 35mph i can feel a vibration if i floor it its fine, but soon as cruise its back again lol
Simon72
  • Wolverhampton
Re: clutch
« Reply #8 on: 23 December 2010, 19:24:47 »
Could it be a CV joint on the rear or even a U/J on the propshafts??
ajay_2.2dti
Re: clutch
« Reply #9 on: 23 December 2010, 19:32:12 »
ive been to the car garage, and he said the propshaft were fine, coz thats what i fort,
Re: clutch
« Reply #10 on: 23 December 2010, 20:47:53 »
If it's juddery just as you pull away, as you describe, then the clutch is probably worn or contaminated so it would be worth changing it, IMHO. Make a careful check for oil or other fluids leaking onto the clutch while you're at it though. Maybe the gearbox oil is getting on the clutch?
ajay_2.2dti
Re: clutch
« Reply #11 on: 23 December 2010, 21:22:05 »
does any 1 fancy changing a clutch on my omega lol ;) ;)
Welung666
Re: clutch
« Reply #12 on: 23 December 2010, 21:28:59 »
Where are you Ajay?
ajay_2.2dti
Re: clutch
« Reply #13 on: 23 December 2010, 21:38:13 »
mablethorpe in lincolnshire
Welung666
Re: clutch
« Reply #14 on: 23 December 2010, 21:43:18 »
Bit far from me then (I'm just north of Birmingham) although I do have family in Lincoln (outlaws).
Page created in 0.043 seconds with 20 queries.
