Author Topic: losing coolant quite bad  (Read 3687 times)
Mr Stud
  • somerset
« on: 02 January 2011, 15:53:20 »
put about a litre of water back in to coolant bottle a week ago,and now says it needs topping up again...where are these that highlighted to on the car
1. Hbv
2. Leaking Bottle or Cap.
3. Leaking "Dowty Washers" on the Coolant Bridge.
4. Thermostat
5. Oil Cooler Plate.
 have changed the hbv valve....would you be able to see the coolant leaking on any of the above...
is there anywhere else that it could leak out off....
the car is running fine with no issues only problem is it does steam abit out the exhaust,could this be anything to do with it
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
Re: losing coolant quite bad
« Reply #1 on: 02 January 2011, 17:14:24 »
There is a coolant shut off valve for the interior heating that has been known to leak. There are 3 pipes going to the valve and it is vacum controlled.
« Reply #2 on: 02 January 2011, 18:22:34 »
Thats the HBV mate, and the OP has already changed it.
Washers on coolant bridge is at back of engine in the 'V', and the oil cooler plate is also in the 'V' - see maintenance guide for oil cooler replacement
Howto -   http://www.omegaowners.com/forum/YaBB.pl?num=1221081908
Parts diag - http://www.omegaowners.com/forum/YaBB.pl?num=1211220529
« Last Edit: 02 January 2011, 18:25:41 by dbug »
tidla
  • solihull
« Reply #3 on: 02 January 2011, 18:32:41 »
1. Hbv
4. Thermostat
with some antifreeze mixtures/colours it can be difficult to spot a leak.
might be worth draining the cooling system and refilling with the bright pink/red antifreeze for a week or two, then go looking at the usual suspect areas.
Mr Stud
  • somerset
« Reply #4 on: 02 January 2011, 19:19:26 »
1. Hbv
4. Thermostat
with the way it going can nearly drain itself..... :) :) :)
Mr Stud
  • somerset
« Reply #5 on: 02 January 2011, 19:30:27 »
would i be able to tell if i take the top of the engine and look.......does the parts come with oil cooler or can the parts be got seperate if it is that...
markfree
« Reply #6 on: 02 January 2011, 19:49:43 »
Easiest way to find your leak is to take off the bag-pipes at the front of the enging, shine a torch in there and if you can see any coolant then it's pretty likely it's either thermostat, oil-cooler plate or coolant bridge.
Whip the inlets off and dry up all the coolant and then do a pressure test (there's a guide how-to-do-this) and that should pin-point your coolant leak  :y
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
« Reply #7 on: 02 January 2011, 20:16:12 »
1. Hbv
4. Thermostat
I wouldn't worry too much about this as is usual for these.  :y
Mr Stud
  • somerset
« Reply #8 on: 02 January 2011, 20:17:10 »
the what pipes?although i would probably understand once i see them when i open bonnet :) :)
pressure test looks a good way to go to find it,can get the bits in work to do that so easy enough
« Reply #9 on: 02 January 2011, 20:30:12 »
Two big black pipes connected to throttle bodies at front of plenum :y
Mr Stud
  • somerset
« Reply #10 on: 02 January 2011, 21:22:27 »
ah i know what they look like now,knew i would thanks....... :)
2nddaniel
  • Heywood
  • I swerve for HGV's.
    • Omega 3.0 V6 Elite
    • Cheesey peas
« Reply #11 on: 29 April 2016, 20:05:20 »
Love this forum. Thanks to everyone's discussions above, I've been able to track down a coolant leak that let steam rise from the bonnet at seemingly random moments that I couldn't replicate at home.
HBV valve. I don't know what the abbvs stand for, but I'll be replacing it. It gushes when I turn the heater to cold and stops when turned to hot. Looked for it after reading this post.
I send my thanks back in time to 2011.
Weapons officer, prepare to fire.
I am prepared. I'm the weapons officer.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 29 April 2016, 20:23:14 »
HBV means Heater Bypass Valve, and is a common failure on common Vauxhalls. Which means it's readily available, from about £6 upwards depending on whether you feel the need for a dealer-supplied part.
