Author Topic: Alarm!  (Read 1417 times)
tonyyeb
  • Salisbury
Alarm!
« on: 11 January 2011, 19:54:58 »
I park it, double-click the fob, and within 5 mins or so the flashers are going off  [smiley=cry.gif]
It's not hugely predictable, but it's doing it more recently. I know there are likely to be a myriad of possible causes, but i'm assuming that it's happened to at least one of you before, and there may be a common or most likely cause?
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: Alarm!
« Reply #1 on: 11 January 2011, 19:56:38 »
Is the alarm going off or just the lights flashing
tonyyeb
  • Salisbury
Re: Alarm!
« Reply #2 on: 11 January 2011, 19:59:26 »
Just the repeater lights. It's been too dark to check whether or not the power-sounder has actually been disconnected.....
Welung666
Re: Alarm!
« Reply #3 on: 11 January 2011, 20:03:31 »
You need to check and disconnect it if it is still there. If not, hit the running man switch before you lock it and see if it goes off. If it doesn't something is tripping the sonics, if it does then move on to the bonnet switch. Unplug it and try again. iIf it doesn't go off then the bonnet switch is either bent to low or it's faulty.
Page created in 0.976 seconds with 20 queries.
