Author Topic: LSD Oil and general inspection question  (Read 5602 times)
Filth_Mobile_Jim
  • Cranbrook, Kent
Re: LSD Oil and general inspection question
« Reply #15 on: 13 January 2011, 17:12:02 »
Just out of interest, which oil did you use? That way i wont get that!
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #16 on: 13 January 2011, 18:03:30 »
I've very recently had an issue with my LSD (yesterday) and ordered these from Opie Oils:
Silkolene BOA 90 LS High Performance Gear And Limited Slip Differential Oil -1 Litre
REDLINE Limited-Slip Differential Friction Modifier / Break-in Additive -0.118L (4 US Fluid Ounces) Bottle
They'll both be here tomorrow :)
Filth_Mobile_Jim
  • Cranbrook, Kent
« Reply #17 on: 13 January 2011, 18:44:04 »
Whats that stuff do then?
P6UL K
  • Dartford, Kent
« Reply #18 on: 13 January 2011, 18:47:14 »
http://www.opieoils.co.uk/p-6320-redline-limited-slip-differential-friction-modifier-break-in-additive.aspx
Filth_Mobile_Jim
  • Cranbrook, Kent
« Reply #19 on: 13 January 2011, 18:51:17 »
Thanks for that, interesting reading. Ive bought some Fuchs Silkolene BOA 90LS Gear & LSD Oil 1L Race/Rally off ebay. Going to put that in and see how i get on.
« Reply #20 on: 14 January 2011, 10:25:19 »
I might be wrong, but I thought the BOA90LS already has the correct friction additives?
Filth_Mobile_Jim
  • Cranbrook, Kent
« Reply #21 on: 14 January 2011, 18:12:27 »
I think so. The additive is there to reduce temps during initial running of a new diff, where the clutch packs and bearings are tight and you get higher than normal temperature.
Filth_Mobile_Jim
  • Cranbrook, Kent
« Reply #22 on: 14 January 2011, 18:16:59 »
Not like the GM additive which is just a viscosity modifier. Again this is just info ive found reading the internet, so as with most internet knowledge , it could be complete balls!
« Reply #23 on: 14 January 2011, 19:57:25 »
I thought so too .. Paul is probably best off giving Opie a bell though if we're not 100% sure; Simon/Guy/(I'm sure there's a third fella) will know I'm sure.
P6UL K
  • Dartford, Kent
« Reply #24 on: 14 January 2011, 20:00:44 »
Too late lol
It all turned up this morning, looks like the diff oil has the slippery stuff in it already!  Never mind, i have some spare for the Rs box then  :y
« Last Edit: 14 January 2011, 20:01:20 by P6UL_K »
« Reply #25 on: 14 January 2011, 20:13:27 »
Too late lol
Opie is always quick on the delivery :) But I meant call them before putting it all in the diff ;)
P6UL K
  • Dartford, Kent
« Reply #26 on: 14 January 2011, 20:39:53 »
Ahhhh... Well the plan is to do it on Sunday as the chatter is getting every so slightly more noisy, so ideally i would like to get the oil in there asap.
« Reply #27 on: 14 January 2011, 20:54:02 »
After some considerable googling I found a discussion surrounding the clutch-type LSDs in Subarus, and the BOA 90LS was the recommended oil for those (with no additional additives needed)  :y
P6UL K
  • Dartford, Kent
« Reply #28 on: 14 January 2011, 20:56:43 »
Ah really?  Thanks for that!!  :y  :y  :y
« Reply #29 on: 14 January 2011, 21:03:55 »
Just in case anything goes wrong.. it's not my fault  ;D But yep, that was as good confirmation as I could find - the Silkolene website shows only bike oils and their datasheets are .. not much use to me  :-/
