Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: bigdavy60  (Read 9406 times)
bigdavy60
  • west of scotland
Re: bigdavy60
« Reply #60 on: 17 January 2011, 13:32:01 »
Glad to hear you found a pump in the fuel tank. I was beginning have doubts.   :y
   ill let you know how it goes mate fingers crossed
greenfingers 79
Re: bigdavy60
« Reply #61 on: 17 January 2011, 14:52:32 »
yes was my 2.2dti with starting problems and the lifter pump in the tank is exactly the same as posted pics for the 2.5td
20 min job :y
bigdavy60
  • west of scotland
Re: bigdavy60
« Reply #62 on: 17 January 2011, 22:37:07 »
20 min job :y
where are these pics posted mate
Kneepad
  • West Scotland
Re: bigdavy60
« Reply #63 on: 17 January 2011, 22:50:17 »
20 min job :y
Way up above in another post, here they are again:
http://www.omegaowners.com/forum/YaBB.pl?num=1251298222
bigdavy60
  • west of scotland
Re: bigdavy60
« Reply #64 on: 17 January 2011, 23:08:19 »
20 min job :y
yeah very good info there mate ill get stuck into that tomorow, lets hope we get a result watch this space. cheers
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: bigdavy60
« Reply #65 on: 17 January 2011, 23:09:00 »
Fergy wrote
I agree with Boditza. Try reading the codes. As far as I remember there are only 2 or 3 codes relevent to pre heating, as follows.
P 1694- Glow plug indicator lamp/ wiring fault
P 1694 - Has another explanation that I have forgotten, but it is associated with the Glow plug indicator lamp
P 1635 - Mal function in glow plug heating  and control circuits.
The first is pretty self explanitory and the third can account for one or more glow plugs open circuit, wiring problems or glow plug control module fubared or just about any other pre heater malfunction other than the indicator bulb/ wiring.
It is not unknown to have all four glow plugs fubared and  the car will still start quite easilly in warm weather.  They are easy to test - pull off the caps (they have a release clip) and they should read about 1 ohm tested to earth in situ with a meter. If you have any that are higher resistance they are fubared.
Glow plug control module sits in the big black triagular plastic box on top of your battery.You are looking for a finned aluminium box about 9cm by 4cm right in the bottom of the triangular box. Part is common to several GM cars and is often held in stock by a decent dealer. GM# 55354141
IIRC you have changed the battery, so will have disturbed this module? It may be worth getting it out and checking all contacts are good, but see what the codes indicate first. When I had this problem I noticed that on distrurbing this plastic box, my starting problem disappeared, but returned a week later.
PS 2.2Dti has no lift pump
20 min job :y
Shomething wrong here shurely? :-/ :-/ :-/
Kneepad
  • West Scotland
Re: bigdavy60
« Reply #66 on: 17 January 2011, 23:30:05 »
See earlier post.
BigDavy's Vauxhall man told him there was no lift pump in the tank.  ;)
bigdavy60
  • west of scotland
Re: bigdavy60
« Reply #67 on: 18 January 2011, 14:32:10 »
See earlier post.
hi guys i have opened the tank , guess what there is def no pump, we have a fuel gauge sender unit , a swirl pot , and a filter on the end of the pick up pipe which is totally covered in thick black gunge, it looks identical to the pictures posted for the 2.5 but no fuel pump in the housing or wiring i may add,however im going to clean the whole thing up and reasemble it surely this must have been restricting the fuel flow in some way,ill leave the car over night to see if this does the job,fingers tightly crossed.  [smiley=undecided.gif] [smiley=undecided.gif] [smiley=undecided.gif]
ps is it possible some 2.2,s have the pump and some dont?
« Last Edit: 18 January 2011, 14:41:33 by bigdavy60 »
bigdavy60
  • west of scotland
Re: bigdavy60
« Reply #68 on: 18 January 2011, 14:36:23 »
20 min job :y
it gets stranger by the day ,no pump in my tank ,please see my reply to kneepad mmmm?
« Last Edit: 18 January 2011, 14:39:02 by bigdavy60 »
greenfingers 79
Re: bigdavy60
« Reply #69 on: 18 January 2011, 16:00:01 »
ok maybe it werent a pump :o :o :o :o :o
but looked similar to the 2.5td pictures.
didnt completely strip just cleaned filter off the bottom.
since ive done that there is a strange clicking noise coming from the tank or near it, primer pump perhaps but does not stop untill car is started?
Pages: 1 2 3 4 [5]  All   Go Up
