Author Topic: Door lock buttons rattling  (Read 4556 times)
mathewst
  • Split, Croatia
    • v40
Re: Door lock buttons rattling
« Reply #15 on: 18 January 2011, 09:52:01 »
No need to remove the window triangle.
It is normal that it is stuck on window part cause there are metal pins that hold the door card to the metal of the door.
Actually the pins hold the rubber strip that is glued to the door card
Try to pry it out with th screwdriver.
The rubber strip will probably fall off in the process but you can glue it back on
Boditza
  • Craiova, Romania
« Reply #16 on: 18 January 2011, 10:06:18 »
its already ripped from the door card... the card sits 1 cm apart from the window. how will i pry it out?? from the side? use the door card as a leverage?? i have a verry bad habbit in breaking things so i'm sorry for the annoying questions :)
mathewst
  • Split, Croatia
    • v40
« Reply #17 on: 18 January 2011, 10:30:41 »
You removed all the screews, including the one near the tweeter?
Boditza
  • Craiova, Romania
« Reply #18 on: 18 January 2011, 11:19:17 »
all of them... printed the guide and folowed exactly.. with pics..
mathewst
  • Split, Croatia
    • v40
« Reply #19 on: 18 January 2011, 12:15:06 »
What part of the door card is stuck?
Boditza
  • Craiova, Romania
« Reply #20 on: 18 January 2011, 12:21:30 »
the upper part... where that part usualy brakes.. it seemed like it was stuck in that
mathewst
  • Split, Croatia
    • v40
« Reply #21 on: 18 January 2011, 12:57:32 »
That is strange since there is nothing there that can stuck onto something especially if the rubber strip  next to window is loose from the door card.
Boditza
  • Craiova, Romania
« Reply #22 on: 18 January 2011, 13:12:40 »
its not completely loose... only half.. the door lock half is, th efront is still sticked onto it :)
mathewst
  • Split, Croatia
    • v40
« Reply #23 on: 18 January 2011, 13:19:46 »
Then pry it out with the screwdriver or rather try pushing the whole door card from the bottom up (even carefully hitiing it from the bottom up).
Rubber strip is connected to the door card but never mind if it comes of it can be glued back on (glue is holdin it).
The only thing keeping the door card on the the door should be that rubber strip if all screws are removed.
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« Reply #24 on: 18 January 2011, 13:23:06 »
wow popular problem! I have just lived with it for 4 years but found it annoying
www.impactcls.co.uk - Flight Case Manufacture
Boditza
  • Craiova, Romania
« Reply #25 on: 18 January 2011, 16:17:16 »
i'll get my hands on it tomorow and try it again... my old astra ratled but eventualy stopped.. dunno why but i never asked =))
Page created in 0.027 seconds with 16 queries.
