Pages: 1 [2] 3  All   Go Down
Author Topic: breakdown!  (Read 5991 times)
Aundie
  • cowdenbeath, Fife
    • 1999 2.5 Reflection
Re: breakdown!
« Reply #15 on: 08 December 2010, 14:45:30 »
anyone?
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
Re: breakdown!
« Reply #16 on: 08 December 2010, 15:24:39 »
There's a diagram in this thread:
http://www.omegaowners.com/forum/YaBB.pl?num=1262391402/4#4
Tried to copy/paste it in but it wouldn't do it....
Kneepad
  • West Scotland
Re: breakdown!
« Reply #17 on: 08 December 2010, 15:31:42 »
any help with water pump location please!
does this belt affect timing at all?
No effect on timing.    :y
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #18 on: 08 December 2010, 15:53:54 »
guess the tensioner is done! should i be able to turn it by hand? i cant
Welung666
Re: breakdown!
« Reply #19 on: 08 December 2010, 16:03:07 »
Bearings are siezed then. Ask andyc when you ask about your aux belt :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: breakdown!
« Reply #20 on: 08 December 2010, 16:12:06 »
If you update your profile with your location maybe one of us can help  :y
Re: breakdown!
« Reply #21 on: 08 December 2010, 16:34:28 »
WP is the water pump.  :y
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #22 on: 08 December 2010, 19:07:04 »
is the tensioner an easy fix?
Re: breakdown!
« Reply #23 on: 08 December 2010, 19:17:58 »
You just want the tensioner wheel with the bearing.  Undo nut in centre (15mm), remove old, fit new and retighten nut  :y  2 minutes!!  Refit belt as per diagram above.
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #24 on: 08 December 2010, 19:40:53 »
exellent you lot have saved me some serious time before i've even started. ;D
one other question i have a front wheel hub to replace also and have read some silly torque figures for tightening it! over 300nm would i just get away with tight as i can on a 3' bit of scaffhold?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: breakdown!
« Reply #25 on: 08 December 2010, 19:52:28 »
If it really does have to be that tight, use a trolley jack to raise the 3ft Scaff Bar on a very good ratchet and socket, then lower/raise/lower/raise etc until you have reached the desired torque.  :y
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #26 on: 08 December 2010, 19:59:37 »
thing is cant find a torque wrench that goes that high!
Kneepad
  • West Scotland
Re: breakdown!
« Reply #27 on: 08 December 2010, 20:10:40 »
Do the work then ask your local garage to torque it up for you.
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #28 on: 08 December 2010, 20:19:17 »
that's the plan mate cheers for all your help!
Aundie
  • cowdenbeath, Fife
Re: breakdown!
« Reply #29 on: 23 December 2010, 19:22:57 »
belt fixed folks new issue now broken (hall)? sensor so my mate says car runs but not as sweet as usual engine managment light on but goes out at high revs.
does that sound like a proper diagnosis?
Pages: 1 [2] 3  All   Go Up
