Author Topic: Engine light  (Read 2111 times)
J18BES
Engine light
« on: 19 January 2011, 19:00:22 »
Well just drove to missis and running fine and calm then the engine light come on. Stoped car and turned off had check over and everything were should be turned back on and light still on but driving fine.
Any ideas?
Re: Engine light
« Reply #1 on: 19 January 2011, 19:05:20 »
Any ideas?
Have a look here & do a 'pedal trick'
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
J18BES
Re: Engine light
« Reply #2 on: 19 January 2011, 19:23:51 »
Does it work?
Re: Engine light
« Reply #3 on: 19 January 2011, 19:34:27 »
Does it work?
Only you can tell us that, you've got the keys to your car.  :-?
J18BES
Re: Engine light
« Reply #4 on: 19 January 2011, 21:49:08 »
After about 20 times doing it as it flashes so quick
Code 0430??
Welung666
Re: Engine light
« Reply #5 on: 19 January 2011, 21:51:38 »
P0430 Cat efficiency Bank 2 (passenger side)
What fuel are you using?
J18BES
Re: Engine light
« Reply #6 on: 19 January 2011, 22:02:28 »
normal unleaded from texeco
the petrol light had come on to
Re: Engine light
« Reply #7 on: 19 January 2011, 22:04:30 »
that's cos you'd got down to your last couple of gallon-ish ........ if you'd left it, it would've started to flash.  :y
J18BES
Re: Engine light
« Reply #8 on: 19 January 2011, 22:51:00 »
so will it clear off?
Welung666
Re: Engine light
« Reply #9 on: 20 January 2011, 08:14:05 »
After about 20 starts without the error re-occuring. Try running through a couple of tanks of branded premium fuel :y
J18BES
Re: Engine light
« Reply #10 on: 20 January 2011, 11:38:59 »
i dont get enough with the standard unleaded lol  :'(
Re: Engine light
« Reply #11 on: 20 January 2011, 11:47:36 »
0420/0430 codes are "common" on the 2.6 / 3.2 engines .. it's not a matter of "if" they occur .. more "when" they occur.
The "fault" - and IMHO it is NOT a "fault" as such - seems to be triggered by a "change" in the exaust gas composition that passes through the small pre-cat .. the sensors are either side of this and NOT the main cat.
I get the fault twice a year, almost without fail .... just after arriving in France, and just after returning from France ... ie, after refuelling with a "different" fuel.
Now there is no "proof" of this as such .. just my experience. I remove the codes with the GS500 and things are fine for the rest of the year.
What folks are saying... is you may have changed the fuel you put in  ... another service station/supermarket/different fuel .. It's also possible that running the tank low has dragged some crap from the bottom of the tank through the engine, the burning of which has "upset" the sensors into thinking the cats are failing ...
by refueling with a "quality" fuel for a couple of tankfuls the light might well go out on its own as the system settles down.
If not, post up your location and there may be someone close who can use a code reader/resetter to do it for you.. :)
HTH :)
edited for smelling pistakes .. :)
« Last Edit: 20 January 2011, 11:52:19 by entwood »
J18BES
Re: Engine light
« Reply #12 on: 20 January 2011, 23:31:47 »
Im over In worcester and also work on the Strensham North Services on the m5
