Author Topic: Rear v6 mains cap removal - any ideas?  (Read 2079 times)
paulg
  • Spalding
    • 04 3.2 manual MV6
« on: 01 February 2011, 21:00:22 »
Evening all! does anyone have any handy tips to remove the rear mains cap on a 3.0l without bending the bolts, ive had a go, but dont want to cause any more damage! :-[
Bent valve
Re: Rear v6 mains cap removal - any ideas?
« Reply #1 on: 01 February 2011, 21:39:47 »
Use a big bar till it comes undone, you are turning the right way I presume ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 01 February 2011, 21:52:50 »
Sorry if this is a daft question, but what is the mains cap?
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #3 on: 01 February 2011, 21:53:09 »
what I meant was, Ive undone the cap bolts but, have put some back in to rock the cap free, but wont budge.
« Reply #4 on: 01 February 2011, 21:53:44 »
Saves me asking Russ :D
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #5 on: 01 February 2011, 21:54:14 »
The mains caps are what hold the crank in.
« Reply #6 on: 01 February 2011, 21:54:46 »
Ah........main bearing caps :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #7 on: 01 February 2011, 21:55:19 »
Ah, Thanks for that!
Rob, at least I'm not the only dafty!  Must be a Bristolian thing!  ;D
Bent valve
« Reply #8 on: 01 February 2011, 21:55:50 »
If you have removed the bolts, give the cap a smack with a rubber hammer :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #9 on: 01 February 2011, 21:55:52 »
Dont pretend like you know now!  :-X
« Reply #10 on: 01 February 2011, 21:57:16 »
Bristol born & Bristol bred...........strong in the arm & thick in the head ;D ;D ;D ;D
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #11 on: 01 February 2011, 22:20:08 »
If you have removed the bolts, give the cap a smack with a rubber hammer Thumbs Up!
Tried that, & with a bigger hammer & punch, but only moves about .5mm aswell as wiggling the crank.
Bent valve
« Reply #12 on: 01 February 2011, 22:27:32 »
Tried that, & with a bigger hammer & punch, but only moves about .5mm aswell as wiggling the crank. [/quote  Hit it harder with a bigger hammer then! you're only other option is to talk nicely to it ;D
« Last Edit: 01 February 2011, 22:28:15 by Bent_Valve »
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #13 on: 01 February 2011, 22:31:13 »
I think i might have to take it of the stand & t**t the crank with a block of wood! as it aint listening! :'(
2woody
  • Northumberland
« Reply #14 on: 02 February 2011, 08:22:02 »
it's the RTV down the side of the bearing cap that's holding it in.
replace the two bolts with either two less critical ones or bits of bar and continue the levering process - that's definitely the way to do it.
Page created in 0.029 seconds with 17 queries.
