Author Topic: autobox,not changeing gears properly  (Read 3891 times)
v6power
  • North manchester
Re: autobox,not changeing gears properly
« Reply #15 on: 30 January 2011, 17:27:13 »
its always when it tries to select 3rd or at low revs you lift of and back on again and doesnt find a gear and just revs unless u revs the nutts of it in which case it jumps in.
« Reply #16 on: 30 January 2011, 19:46:12 »
Sounds like the 2-3 solenoid. Sump off jobbie. Have a read of this and note "Figure 2" part #307 http://images.omegaowners.com/downloads/Autobox_Docs/4L30E_Article.pdf
v6power
  • North manchester
« Reply #17 on: 30 January 2011, 20:38:28 »
Found these guys and iam gonna go take it in the morning for them to have a look because iam not the best at spannering. If it is the 2-3 solonoid is it a big job to change is the part dear does anyone know?
http://www.automaticgearboxes-lancashire.co.uk/contacts.html
sassanach
  • trowbridge
« Reply #18 on: 30 January 2011, 21:30:24 »
easy job, drop rear sump, pull roll pin holding solenoid in place,refit new or s/h one (if using s/h then check resistance 17.5-18.5 ohms)refit sump,refill, drive away. :y
osealy
  • dublin
« Reply #19 on: 30 January 2011, 21:48:42 »
My standby does 1 2 nothing sometimes, other times fine.
I have an AR 35 but don't feel up to a swap. Would you change just 2/3 solenoid or whole valve box ,or whatever it's called?
v6power
  • North manchester
« Reply #20 on: 01 February 2011, 14:03:30 »
Read the codes which showed solenoid 2-3 fault. So £260 for parts and labour but that includes a full gearbox service so hopefully that should sort that.
v6power
  • North manchester
« Reply #21 on: 02 February 2011, 13:58:18 »
Well thats the gearbox done and dusted it now runs as smooth as when it was made. Result. Full service in the morning, wash, wax, piccys to upload. cheers for all the help ppl. :y
