Author Topic: Re-filling coolant from empty (water pump removed)  (Read 2554 times)
Re: Re-filling coolant from empty (water pump removed)
« Reply #15 on: 07 February 2011, 20:07:20 »
how old is the coolant? I personally would be tempted to flush the whole coolant system (with heaters on full) with clear water, then run 50/50 mix through as per my maint guide. It does waste a little coolant, but it ensures you have a good 50/50 mix around the entire system.
Keep that oil cooler and head gasket happy  :y
If you flush with water until it's clear then add 5 litres neat when filling you know the concentration will be right without wasting any. :y
True, thats a much better way. But i recall the coolant system on 4pots is slightly smaller, think thats why i did it the way i did  :-/
May well do that TBH Tunnie.
There is no doubt in my mind that this car has been seriously neglected by it's previous, (2nd) owner.
HG & Oil Cooler failures are caused by poor coolant maintenance, for the minimal cost, its worth it  :y
