Author Topic: Snapped airbag connector!! Help please!  (Read 3095 times)
Julian James
  • Birmingham
« on: 09 February 2011, 15:36:18 »
Hey guys...
Yesterday I fixed the heated seat on pass side.  Today I went to do my drivers seat, and on removing the plugs, I snapped the clip on the yellow airbag connector!
Any tips?  I'm guessing I can't just superglue it?
I'm obviously car-less (barring friends giving me lifts) as I can't plug up the battery again until the airbag is reconnected, otherwise I will get the permanent airbag light on the dash.
Here's a picture of the connector from someone else's thread.  Mine is yellow instead of grey, and has the same purple bit.  It's the clip on the side that has broken off.
http://www.omegaowners.com/forum/YaBB.pl?num=1296819520/0
It's the bottom picture.
Not sure if it's possible to re-wire a new plug.  Perhaps cut the old and solder the wires together to a new one?
Any help greatly appreciated.  Thanks.
Julian
« Last Edit: 09 February 2011, 15:40:13 by Julian_James »
iainb
  • West Midlands
Re: Snapped airbag connector!! Help please!
« Reply #1 on: 09 February 2011, 15:40:22 »
The picture wont load mate.
But is it possible to thread a cable tie to hold the two halves together ?
omegabsw
  • Essex
« Reply #2 on: 09 February 2011, 15:40:36 »
I cant see the pic but if it was the same as my Astra had then you will either have to glue or tape the clip or resolder it into a blank
« Last Edit: 09 February 2011, 15:41:04 by omegabsw »
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #3 on: 09 February 2011, 16:07:49 »
Broke mine when I had the seat out, just held together with a tie wrap...
« Reply #4 on: 09 February 2011, 18:34:27 »
Thought this t shirt was a limited edition. :-/
Seems that everyone has got it. ::)
Plug it back in as is and it will be fine, it will eventually work loose though, putting the light on. :-/
A pair of thin 3" cable ties threaded between the wires will hold it together nicely.  :y
Fixed mine like this not had a problem since. (furiously finds some wood to touch). :-X
Julian James
  • Birmingham
« Reply #5 on: 09 February 2011, 21:08:14 »
lol al.
thanks guys.  story so far:
Vauxhall wont sell me a new one.  They only sell the entire loom as a whole.
Found a breakers with an omega, but connections were cut out when seats were taken (I saw the same one 2 weeks ago when looking for a window!)
Gonna try breakers yards first thing tomorrow.
If not, i will bodge it, maybe solder a normal audio connector that locks (like XLR or jack! lol), or even hardwire it in direct.
Obviously my preference is to find a replacement connector at breakers.  Looks like it's very simple swap, 10 second job.
We shall see in the morrow!
« Reply #6 on: 09 February 2011, 21:10:36 »
Found a breakers with an omega,  ....
I'd have thought other Vauxhalls would've had the same connector.  :-/
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 09 February 2011, 21:41:41 »
If its a new plug or socket your after try these people
http://www.ccsukltd.co.uk
They do most connectors under the Sun or can point you in the right direction.
Chris
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 09 February 2011, 23:02:52 »
Personally I would solder it, I can't imagine you needing the seat out again.  ::)
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #9 on: 10 February 2011, 00:34:06 »
bodge it who cares, lets be honest these cars aren't going to be on the road forever and if you do sell it on the new owner can expect a few bodges forr the money you would get for it!! and it's a seat hoe often do they get removed!! ;)
Warning: Dates in Calendar are closer than they appear.
Julian James
  • Birmingham
« Reply #10 on: 10 February 2011, 00:46:40 »
very good point Andy B... lol  That might give me a lot more sources tomorrow!
Bodge / Soldering might be a quick way, but if my bodge-soldered heated seat repair doesn't go to plan, I could have the seat out sonner than expected!!
mrgreen
  • Salzburg/austria
« Reply #11 on: 10 February 2011, 00:53:39 »
o.k if that's the case take some off the shelf connectors and put it all together i mean at the end of the day you could use anything you have to hand to make the connection! strip the wires and tape them together if you were that way inclined!! all you need is the connection
« Reply #12 on: 10 February 2011, 09:29:28 »
You didn't own my first Nissan, did you? That's how the cam sensor was attached..  ;D
Julian James
  • Birmingham
« Reply #13 on: 10 February 2011, 12:12:18 »
I have just got back from the scrappys and got myself not 1, but 2 of the connectors, just incase ;)  Including the female end too, you never know...
Seat is back together and will hopefully be a simple job now of changing the male connector and re-installing.
Feel much better now!  8-)
Thanks guys
Julian James
  • Birmingham
« Reply #14 on: 10 February 2011, 16:30:39 »
Connector swapped.
Seat in.
Battery on.
No warning lights, and no airbags going off in my face.
Good times!  :y
