Author Topic: engine management light on  (Read 1926 times)
kjf7
  • lincolnshire
« on: 27 February 2011, 21:53:17 »
is there a common reason as to why this would be on on a mv6 3.2 auto 2001 model if so is it likly to be expensive or quite an easy fix thanks all who have helped during my weekend of need although its not over yet! :y
    • 530D M Sport, 330i Coupe
Re: engine management light on
« Reply #1 on: 27 February 2011, 21:56:11 »
Need to read codes - look up pedal trick on here. Wouldn't mind betting your get either P0420 or P0430 or both.
kjf7
  • lincolnshire
« Reply #2 on: 27 February 2011, 22:06:41 »
ok what would they mean as havnt bought the car yet a mates got a tech 2 but the cars 100 miles away :y
« Reply #3 on: 27 February 2011, 22:08:37 »
If you get those codes, it will be failing pre-cats. Nothing to worry about, plenty of information on here.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 27 February 2011, 22:09:25 »
I assume you mean what does the EML Light mean? They let you know there is a problem. As too what the problem is you need to do the Pedal Trick or plug a Tech2 or Code Reader in ..
kjf7
  • lincolnshire
« Reply #5 on: 27 February 2011, 22:18:05 »
heres the ebay no 130485496214 i know this probably wont help but just need an idea as i need a car quick i waas wondering what those codes might mean that matey was betting on as a starting point good to see you mr darth i need your help
Lesopc
  • West London
  • Worlds Biggest GM Fan
« Reply #6 on: 28 February 2011, 00:12:14 »
Not sure about the V6 lump, but when mine came on on my 2ltr it was because the Cam Sensor had packed up. Best to get it checked with fault codes though. On a straight 4 lump it was very straight forward to change.
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
kjf7
  • lincolnshire
« Reply #7 on: 01 March 2011, 21:56:38 »
Hi what r the main problems I need to look for before I buy this mv6 3.2 2001 y reg cheers and thanks again everyone  :y
I_want_an_Omega
« Reply #8 on: 02 March 2011, 08:11:08 »
There are masses of reasons that the EML will come on - basically anything that is controlled or sensed by the ECU.
The ECU will check many many functions when you start the engine, and any one of those could bring the light on.
So, to avoid any doubt you NEED to do the pedal trick or get the codes read properly.
HTH
