Author Topic: Air con help needed  (Read 1398 times)
MV6Matt
  • London
    • No car since 2022....
Air con help needed
« on: 01 March 2011, 06:02:13 »
I've noticed that the air con has stopped blowing. Pressing the 'big' fan (this is a p/f climate control dash) no longer results in any increase in air blowing through.
Temperature is fine - gets hot and cold - just no air blowing through.
Any headers to threads up already and/or pointers to likely reasons much appreciated. Nothing specific in the maintainance guides (that I can see - please let me know if I've missed it) so pointers to previous threads would seem the most likely place I guess.
Matthew
« Last Edit: 01 March 2011, 06:07:57 by MV6Matt »
(thanks Ian)
MV6Matt
  • London
Re: Air con help needed
« Reply #1 on: 01 March 2011, 19:02:21 »
....anyone able to help point me in the right direction?
(thanks Ian)
« Reply #2 on: 01 March 2011, 19:31:27 »
Have you checked fuse #33 in cabin box. Top L/h corner, green maxi fuse
MV6Matt
  • London
« Reply #3 on: 02 March 2011, 07:10:50 »
No I haven't - thanks for the tip :y :y
I'll check it out today
Matthew
(thanks Ian)
MV6Matt
  • London
« Reply #4 on: 02 March 2011, 19:24:24 »
Just been to check the fuse - took it out-  had a gander. Absolutely fine. :-?
Turned the engine on and let it run - turned the a/c on and bingo- lots of noise. Must have been the fuse not being in properly (I thought happily). :)
However, in putting my hand up against the blowers it's still not blowing anything through - it just sounds like it is now. :(
Where next? under bonnet or check for blockages from the dash side? Or both? :-[
any ideas send 'em in this directions, please!
Matthew
(thanks Ian)
Page created in 0.038 seconds with 20 queries.
