Author Topic: elite estate rear self levellers  (Read 3671 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« on: 02 March 2011, 16:55:24 »
does anyone know if monroe LA361 shocks are compatible with the elite set up,my local factor lists them for the estate at £115 per pair complete with air connectors but I am not sure if they can be connected to the existing pipework or wether they are designed to be pumped up with a footpump via schrader type valve.My elite has been garaged over the winter and I have just noticed that the n/s shock is leaking oil :'(
thanks
Henry
other rides
Re: elite estate rear self levellers
« Reply #1 on: 02 March 2011, 17:13:55 »
Just googled them before answering, just in case, and they are as I thought... An aftermarket air shock. Afraid it's Vx only AFAIK if you want to keep the self levelling :(
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 02 March 2011, 17:24:27 »
Gosh you are fast lazytinker.
As he says! The VX shocks aren't cheap either, better with a trade card or try Andyc.
henryd
  • west cornwall
« Reply #3 on: 02 March 2011, 17:36:45 »
thanks for the replies chaps,I was hoping the the elites self levelling set up  might work with them but possibly different pressures are needed
other rides
mrjimbo
  • Oxfordshire
« Reply #4 on: 02 March 2011, 17:38:42 »
Bought a pair of Vx self levellers for my estate this morning and they came to £177.55 inc VAT on trade card from the local stealers  :y
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #5 on: 03 March 2011, 00:34:55 »
In my pre TC days I got some Monroe shocks fitted to my elite saloon. There's a regulator and hose in the pack that allows you to inflate or deflate via compressor or pump, you can also use with existing s/l set up, as I have done. All fixings were included. I'll try and see if I can find the part number. I thought the shocks were different between estate and salooon but not sure.
TC and BnQ Trade holder.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #6 on: 03 March 2011, 02:02:28 »
Here's the estate version:
http://cgi.ebay.co.uk/OMEGA-ESTATE-16V-V6-DTI-TDI-AIR-SHOCK-ABSORBER-KIT-/220323955284?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item334c54c254#ht_1179wt_907
Got 'em on mine - excellent for towing too! :y
henryd
  • west cornwall
« Reply #7 on: 03 March 2011, 09:00:14 »
thanks geoff,that helps a lot,saloon and estate are different but the number I listed in my first post are the estate parts,I have got my factor talking to monroe technical as we speak so will post their verdict :y
other rides
henryd
  • west cornwall
« Reply #8 on: 03 March 2011, 09:03:02 »
yep they are the same kit that my factor has,they gave me a good price too,almost half of the ebay price ;)
other rides
henryd
  • west cornwall
« Reply #9 on: 03 March 2011, 11:17:54 »
monroe tech department are sitting on the fence,they won't condone or condemn there products use with the existing set up >:(
other rides
« Reply #10 on: 03 March 2011, 11:29:37 »
I didn't think they could be connected to the standard setup, which seems to be the general train of thought... If they can and work fine I may have a cheaper solution for my leaking rear shock ::)
henryd
  • west cornwall
« Reply #11 on: 03 March 2011, 11:50:16 »
it seems that geoffr70 has done it and all is well :y
other rides
« Reply #12 on: 03 March 2011, 12:02:03 »
Indeed... So, just to confirm geoff, you just replaced the shocks and plugged the manufacturers air lines on so that the standard fitted sensors and compressor run as they did with Vx Shocks?
Page created in 0.028 seconds with 20 queries.
