Pages: 1 [2] 3  All   Go Down
Author Topic: Is this a worn wishbone bush?  (Read 5956 times)
razzo
  • Crapital
    • 97 3.0 Elite
Re: Is this a worn wishbone bush?
« Reply #15 on: 17 March 2011, 14:39:00 »
mine gave up the ghost a while ago so i pressed in poly bushes
Xenon
« Reply #16 on: 17 March 2011, 14:48:19 »
wow I didnt know you could get poly bushes for the rear ones. Where did you get them from?
« Reply #17 on: 17 March 2011, 15:22:31 »
Nothing is allowed to be removed for MOT but the car is jacked up... MOT's are a matter of the tester's opinion... I'd be checking that bush very carefully for play (which is the actual failure) in that state and certainly advising it :y
Play in the rear bushes isn't as bad as the fronts but will still affect the handling and tyre wear ;)
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« Reply #18 on: 17 March 2011, 15:44:50 »
How hard is it to remove old bushes and press in the poly ones?
I've heard all about it, but i've not got access to heavy presses or anything, just some hands and cheap tools lol and maybe a bit of homegrown ingenuity!! :y ::) :D
« Reply #19 on: 17 March 2011, 16:14:51 »
ISTR that Mark DTM managed to break a 10 Tonne Press trying to do some at Newent a few years back :o :o :o
o-meg-a
  • south wales
« Reply #20 on: 17 March 2011, 16:53:39 »
yeah, my thoughts exactly lol.
I knew pressing bushes could be hard, so i will avoid lol
V6 CDX-er
  • Sheffield
« Reply #21 on: 17 March 2011, 16:54:30 »
Ha yeah,
Guy i bought it from lived by the sea.
They not half as bad as the pictures make them look actually, but yeah i plan on giving it all a good rub down when i change the wishbones.
I'm replacing the whole wishbone with cheapo ones right now with 12 month guarantee.
I know lemforder etc have longer, but i'm not paying that much money, and i'm fitting myself so i know i'll do it right, making sure the front bush is aligned correctly when the weight of the car is on it etc in the hope they last as long as possible.
If you'd seen my front tyres then you'd know something was up lol
id say in it!
 :o
I've seen sunken WW2 battle ships that look better  :o
I've just got a set of front lower wishbones, complete with balljoints for £76. Thing is I'm having a bit of a senior moment and cant remember the name of the firm that I got them from  :-[
o-meg-a
  • south wales
« Reply #22 on: 17 March 2011, 16:56:00 »
yeah i just got some for £49.95 delivered, with balljoints and bushes.
V6 CDX-er
  • Sheffield
« Reply #23 on: 17 March 2011, 16:58:19 »
Bargin-tastic  :y
« Reply #24 on: 17 March 2011, 16:58:24 »
These sound like the cheap ones I've been using... They seem to last about 18 months (35-40k for me)  :y
V6 CDX-er
  • Sheffield
« Reply #25 on: 17 March 2011, 17:02:55 »
Sorry for the thread hijack, but I'm in the middle of replacing my wishbones as we speak, and as usual when I touch the spanners, I've come up against a problem.
My new wishbones had new balljoints attatched. I've left the track-rod end in-situ, and I'm really struggling to pop the balljoint back into place. I cant lower the wishbone enough because of the bracket on the rear-most mount and knocking the nipple of the balljoint this way or that isn't helping either.
Any tips please chaps? I've done a quick search but cant find anything to help?
In advance, many thanks  :y
« Reply #26 on: 17 March 2011, 17:11:26 »
Perseverance I'm afraid.... It will go :y :y
I use a 3' Lever Bar to lever down on the wishbone personally, although it doesn't need that much.... I assume you've tried it with the steering turned to full lock/straight ahead? I can't remember what position I find easiest because I just do it without thinking :-[ :-[
V6 CDX-er
  • Sheffield
« Reply #27 on: 17 March 2011, 17:14:24 »
Cheers LD  :y
Been struggling with it all afternoon TBH. First with getting the bolt hole lined up for the rear mount, and now getting the balljoint in. Not easy work when I'm having to look after my 7 month old daughter who wont sleep because she's cutting her teeth.  :'(
« Reply #28 on: 17 March 2011, 17:17:55 »
Cheers LD  :y
Pity you aren't nearer... I'm in no fit state to do it but the moral support of someone who has done a few ( ::)) can be a big help... Think the last change took me just over 2 hours including getting the tools out/away and a cuppa ;)
V6 CDX-er
  • Sheffield
« Reply #29 on: 17 March 2011, 17:21:16 »
Cheers LD  :y
You could always try going outside and shouting words of encouragement? It's only what, 170 miles from me to you? If you shout loud enough I might be able to hear you?  :D
edited because I had spelt "me" incorrectly.
« Last Edit: 17 March 2011, 17:22:03 by V6_CDX-er »
Pages: 1 [2] 3  All   Go Up
