Pages: 1 [2] 3  All   Go Down
Author Topic: Front Wheel Bearing  (Read 4212 times)
Re: Front Wheel Bearing
« Reply #15 on: 24 March 2011, 17:59:00 »
When I did mine Nige I just used a standard 32mm
Well I haven't got a 32mm so if I'm buying one I might as well get an impact one ..  :) and its "only" just under £9 .. then  £35 for the bar .. still .. you can never have too many tools ... :)
My thoughts are simple .. even buying/hiring the tools and parts the bill will be less than £100 ... doubt a garage would do the job for less ... and I'll know its been done correctly .. :)
« Reply #16 on: 24 March 2011, 18:09:29 »
Is it worth doing both? Just a thought but if one's on its' way... :-/
Also an ideal opportunity to check the front brakes over, given the mileage you're likely to be doing over the summer.
« Reply #17 on: 24 March 2011, 18:21:15 »
'Tis a thought ... :) Brakes would be checked  anyway as it was getting a full check before easter anyway. Did the Oil & Filter today as I had the jack out .. :)
« Reply #18 on: 24 March 2011, 23:26:17 »
Did my pass side last week, I had trouble taking out the play, 2 ft breaker, with 3 ft bar and me swinging on the end, still a fraction of play. Couldn't do any more so had to throw it back together, including fitting the hub centre cap.(might be worth getting a new one of these, they can be stubborn and not reseal when refitted)
I have been able to take the play out with these tools before, but not this time  :-?
« Reply #19 on: 25 March 2011, 12:36:21 »
Right ..
Extra tools ... ordered :)
CDK603 .....  ordered  :)
Torque wrench hire .... arranged  :)
How to ....  printed and read .. :)
Which leads to the next question ... "how to" says "hub carrier" bolts are angle tightened ... which I was always taught means don't reuse as stretched ... anyone any part numbers for replacement bolts so I can drop into dealers and pick em up ... I'm guessing 2 per unit ??
« Reply #20 on: 25 March 2011, 12:52:12 »
 90541296 (it`s in the pic ;))
« Reply #21 on: 25 March 2011, 12:56:45 »
well I tried to read the part numbers on both pictures ... and got nothing sensible .... !!
Still don't see either ending in a 6 ...  top one looks more like an 8 .. bottom one more like a 5 !!!
« Reply #23 on: 25 March 2011, 13:06:50 »
Many thanks ... but that says "caliper bolts" .. those are the small ones I believe ... I was after the part number for the larger ones .. that go to 95NM then 30 then 15 .. :)
Sorry to be a pain .. must reinstall EPC at some point !!
« Reply #24 on: 25 March 2011, 13:17:44 »
Caliper bolts are 90541295. T`other ones secure the caliper mounting to the hub (that`s what you`re after innit Nige?)
« Reply #25 on: 25 March 2011, 13:44:16 »
Totally confused now .. :(  Reinstalled EPC and got nowhere .. :(
How to thread,     http://www.omegaowners.com/forum/YaBB.pl?num=1175890350
"Reply #4" .... says "Hub Carrier Bolts 95 Nm then 30 then 15" ....
as well as "caliper bolts 30Nm" ... now the latter ones are the ones you get with new new pads ... not a problem 90541295 ....
there are also .. on EPC ... "CALIPER TO STEERING KNUCKLE  90541296"
but nowhere can I find "Hub Carrier" as the script mentions !!!!
My problem is, once I get this in bits, I'll have no transport to get to the stealers ... so I'm trying to get all the bits in advance .. :)
« Reply #26 on: 25 March 2011, 14:14:57 »
AKA hub carrier & AKA stub axle
« Last Edit: 25 March 2011, 14:15:48 by RobG »
« Reply #27 on: 25 March 2011, 14:18:45 »
Ahhh .. all becomes clear ... :)  Told you I was thick !!!
Many thanks .. can now get the right bolts .. :)
« Reply #28 on: 25 March 2011, 14:19:55 »
Your words not mine ;D ;D ;D ;D :y
« Reply #29 on: 25 March 2011, 15:22:17 »
OK .. with any luck  .. the last question .......  :)
Pictures (and words) at "reply #2" missing .. and I'm guessing they are the actual removal of the hub ...  does this need a "hub puller" or can the hub be "knocked off" from the rear ??? The "book of lies" has it being pulled off by fingers !!! after being torqued to 320 NM ?? I don't think so somehow !!  (Ch 10 section 9 para 6 )
Pages: 1 [2] 3  All   Go Up
