Author Topic: Part no. ID for Air Shocks please anyone ?  (Read 2722 times)
  • Auckland
    • Mazda MPV
Re: Part no. ID for Air Shocks please anyone ?
« Reply #15 on: 27 March 2011, 21:35:25 »
What markings do you have on the springs? 'LA' perhaps?  :-/
Big_Al
« Reply #16 on: 27 March 2011, 21:41:59 »
LA on one O/s     - nothing at all on n/s .   had a real good look
Front springs are paint marked   Orange /grey on top coil &  orange on coil below that.
Any clues in that?  :-/ :-/ :-/
« Last Edit: 27 March 2011, 21:42:39 by Big_Al »
  • Auckland
    • Mazda MPV
« Reply #17 on: 27 March 2011, 21:56:53 »
Mine has LA on the rear (both sides) and IIRC so does chrisgixer.
I haven't measured the rear ride height but does look a bit high  :(
  • Auckland
    • Mazda MPV
« Reply #18 on: 27 March 2011, 22:05:45 »
Another thought.
The rear semi trailing arms tend to wind up (or down?) due the torque reaction from the parking brake, possible aided by an auto box in park.
Did you have the hand brake off and the gearbox in neutral when you did your bounce test?
Big_Al
« Reply #19 on: 28 March 2011, 07:49:03 »
  Ah!  Hand brake was off - but car was IN park.
Am getting ground to wheelarch measurements from an MV6 today so at least we will know the difference between the two models .
will post results on here tonight, :y
Big_Al
« Reply #20 on: 28 March 2011, 21:01:26 »
Intriguing !!!
Don't know if this helps or hinders ...  2001 3.2 Elite Saloon. New rear shockers 7000 miles ago. Engine running, self levelling pump "finished" its business ... :)
Measured at the wheel arch vertically through the centre of the wheel.
F N/S = 675 mm
F O/S = 665 mm
R N/S = 675 mm
R O/S = 685 mm
Now those figures look very like your original figures ...... so what makes you think it's sitting "high" ??
Reply to Entwood:   Re measured my ground to wheelarch sizes again today just to make sure. from ground vertically through centre of wheel as follows
N/s front 660mm
O/s front  660mm
N/s rear 690mm
O/s rear 690mm
just waiting for MV6 all round sizes to be confirmed by Oof member
Will post up when  I have them :y :y
Big_Al
« Reply #21 on: 30 March 2011, 17:47:13 »
Intriguing !!!
F N/S = 675 mm
F O/S = 665 mm
R N/S = 675 mm
R O/S = 685 mm
N/s front 660mm
O/s front  660mm
N/s rear 690mm
O/s rear 690mm
Right then results of the MV6 measure up ! 8-) 8-)
Ground to Wheelarch vertically through wheel center on his own MV6 has been confirmed by Darth-Loo-Knee as: 670mm all round
My car just looks wrong the rear height being 690mm in comparison to the front (660mm) .
It does not sound like much but it looks quite "ugly" to me.
Gonna try & get a set of rear MV6 springs & try them.
Thanks all  for putting up with this  long drawn out issue & all of your good input in the replies.
But I think we may have the answer now . . . . .
Wrong rear springs   ::) ::) ::) ::)
Thanks All             Big Al : :) :) :)
« Last Edit: 30 March 2011, 20:31:53 by Big_Al »
amba
  • Medway towns
    • German V6
« Reply #22 on: 30 March 2011, 17:52:16 »
Well done that man for sticking with it and hopefully getting the answer to the problem.
Will await follow up of this thread, once the correct springs are fitted.
Sure the car will then sit level.
