Author Topic: Understeer help  (Read 1609 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Understeer help
« on: 10 April 2011, 20:55:59 »
I was going round a big roundabout at about 25mph turning right when the rear of the car seemed to try to overtake the front!!!! This caused big understeer.
I have had new rear springs a few months back,,,, could it be the shocks??????
cheers
Paul
davethediver
  • Blackburn, Lancs.
Re: Understeer help
« Reply #1 on: 10 April 2011, 21:06:40 »
Could be or possibly donught bushes?? :-/
P.A. Caron de Beaumarchais
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Understeer help
« Reply #2 on: 10 April 2011, 21:19:32 »
Crap quality rear tyres will do it, but they must be poor to lose it at 25mph.
 :o
Jaguar XJ6
Omegatoy
  • UK
Re: Understeer help
« Reply #3 on: 10 April 2011, 21:39:23 »
spilt diesel will also do it and its more  common than you would think!!
Re: Understeer help
« Reply #4 on: 10 April 2011, 21:43:25 »
you soon learn that when you ride a motorbike, especially near trading estates.  ;) ;)
Re: Understeer help
« Reply #5 on: 10 April 2011, 21:44:09 »
Sounds more like oversteer to me. ;)
If it only did it that once, likely a diesel spill or something, as said.
First thing to do, though, for peace of mind, is to check all the tyre pressures are correct and check tyre condition for uneven or excessive wear.
If you can reproduce it with hard cornering elsewhere (it can always be provoked by unsettling the car, I'm taking about smooth progressive cornering) then it's time to check the suspension over.
Omega 37
  • Northampton
Re: Understeer help
« Reply #6 on: 10 April 2011, 22:01:59 »
New uniroyal tyres & always at 30psi.
the car did not lose grip & skid, it was the body of the car lurching away from the chasis,,,,,, if that makes sense???
Re: Understeer help
« Reply #7 on: 11 April 2011, 01:42:19 »
cheers
Paul
Thats not understeer mate - thats oversteer!! ;)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Understeer help
« Reply #8 on: 11 April 2011, 03:18:38 »
when you had the springs changed did you have mig re-traked???
Solar charger fitted.
If not Broke dont fix it..
mathewst
  • Split, Croatia
    • v40
Re: Understeer help
« Reply #9 on: 11 April 2011, 10:18:59 »
It is easy to check the shocks, just push every corner of the car and see if it immediately returns to normal position. If it doesn't it means the shock is knackered (change in pair).
But this backend problem you describe can be related to shocks only if there was some hole in that roundabout that would cause the jumping of the car and loosing trajectory.
Omega 37
  • Northampton
Re: Understeer help
« Reply #10 on: 11 April 2011, 10:32:07 »
It had done it about 10 times. Did not go over any holes. Rear seems slightly bouncy so will change them as they are only about £40 each from gm
Thanks for replys
