Author Topic: Misfire  (Read 1319 times)
neilr
  • Barnet, Herts
Misfire
« on: 26 April 2011, 15:31:22 »
Hi all got reading of no 4 misfire on code reader wifes 2.6 running a bit rough. I know its probably a plug oroil in the well. But is there any way of checking coil pack without changing it.
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: Misfire
« Reply #1 on: 26 April 2011, 17:00:17 »
just had the same problem on my 2.6
remove the coil pack and inspect for cracks
mine was deffo showing signs of age, several cracks and swollen showing moisture had got inside
replaced coil for £75 and all good again :y
hth
Just chilling in the sun. I wish back in the rain like everybody else
Re: Misfire
« Reply #2 on: 26 April 2011, 18:09:33 »
Change plugs and see if it clears. But does mean going back in under the cable tray a second time if it persists, but you'll have your answer then.
ASAP though, if there's oil in there it will be cooking the rubber boots, may be usable if caught early enough.
neilr
  • Barnet, Herts
Re: Misfire
« Reply #3 on: 27 April 2011, 09:59:15 »
Thanks guys parked up at present til I can strip & check it. I have new cam cover gaskets and seals ready to fit also. its just finding the time at the moment. Maybe Friday as it  will be quiet. ;D ;D ;D
