Author Topic: Intermittant starting problem,  (Read 1769 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« on: 05 May 2011, 16:16:35 »
Problem starting sometimes,engine cranks over,plenty of battery power,but will not fire.
Seems that there is no fuel geting through,but if I bump start it,it fires up straight away,I'm pulling my hair out trying to suss out the fault.
Like I said this only happens now and then,its really a pain in the butt trying to pin it down,no engine management lights on.
Could it be the fuel pump? .
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Intermittant starting problem,
« Reply #1 on: 05 May 2011, 16:19:20 »
try the paper clip to see what codes you have stored,crank sensor could cause this and may not throw up a code
other rides
Greeny18
  • Sandy, Beds
    • 2001 2.6 Estate
« Reply #2 on: 05 May 2011, 16:19:40 »
[size=16]Does it start from cold ok and then has problems warm/hot[/size]
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #3 on: 05 May 2011, 18:27:58 »
Is it petrol or diesel???
If it is a hot engine and diesel, it could well be hot start issue...  If it is anytime (either petrol or diesel), then get your codes (paperclip trick in maintenance guides) and expect to see code 19 for the crank sensor...
blob
  • london
« Reply #4 on: 05 May 2011, 19:07:33 »
i have got the same problem but it wont start fro cold fine when hot.i thought crank sensor would not start from hot??
alfie
  • Gwent
« Reply #5 on: 05 May 2011, 20:36:38 »
Crank sensor was replaced about 2 yrs ago,no smell of petrol when it refuse's to fire,hot or cold no different.As I said it only happens now and then.
I'll try the paperclip test over the weekend,I've never done that before through.
It only needs a tow a few yards before it starts,so it's really baffling me.
                            Thanks for suggestions
                                   Alfie.
alfie
  • Gwent
« Reply #6 on: 05 May 2011, 20:52:11 »
Please could someone point me towards how to do the paperclip test,never done one before.
« Reply #7 on: 05 May 2011, 21:00:17 »
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
alfie
  • Gwent
« Reply #8 on: 06 May 2011, 07:42:48 »
Thanks,that seems simple enough even for me.
alfie
  • Gwent
« Reply #9 on: 07 May 2011, 21:20:49 »
Sorted,tried the paper clip trick,got a code 19.
the cable connecter was at fault,wasn't fully clicked into each other. Cleaned it up,resecured with a new tie and all ok.
    Thanks for the help.
              Alfie.
