Author Topic: idler control valve  (Read 1215 times)
derek89
  • new tredegar, south wales
idler control valve
« on: 12 May 2011, 20:00:44 »
have cleaned valve but engine is fluctuating up to 2000 revs, any helpful ideas please
Re: idler control valve
« Reply #1 on: 12 May 2011, 20:16:44 »
Check all vac hoses, fluctuating idle indicative of air leak
derek89
« Reply #2 on: 12 May 2011, 20:36:40 »
Thanks RobG will try in the morning
« Reply #3 on: 12 May 2011, 21:19:59 »
To check for a vac leak, spray around the vac lines, plenum area etc LIGHTLY with carb cleaner, whilst the engine is running at idle.... if the engine note changes you have found the leak as the carb cleaner is sucked in and burned as unmetered fuel ... fix the leak .. repeat to check .. wipe down with paper towel ..... result .. fixed idle problem plus a nice clean engine   :y :y :y :y :y
