Author Topic: AR35 from 3.2 into 2.5  (Read 5331 times)
Re: AR35 from 3.2 into 2.5
« Reply #30 on: 13 May 2011, 22:14:08 »
 :y.......keep me informed Rich. :y
richdrury
  • mildenhall, suffolk
    • 2000 2.5 v6 cdx facelift
« Reply #31 on: 13 May 2011, 22:24:47 »
just got to get some frontpipe to manifold gaskets tomorow morning, heatshield is missing from the side of my box also and most of the bell housing bolts on miy box were loose  :o
« Reply #32 on: 13 May 2011, 22:26:29 »
Someone been there before then ?
richdrury
« Reply #33 on: 13 May 2011, 22:29:26 »
very much so, loose housing bolts would cause slight movement thus screwing up the main shaft seal :(
« Reply #34 on: 13 May 2011, 22:32:22 »
Bodgitt & scarper garage services by the sound of it. ::)
richdrury
« Reply #35 on: 13 May 2011, 22:33:33 »
i agree, but will be as good as new when im finished ;)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #36 on: 14 May 2011, 09:27:40 »
I'd be interested in any problems encountered, (perhaps you could do a how to?) as I will be swapping the AR25 on my TD for an AR35 soon. :y
richdrury
« Reply #37 on: 14 May 2011, 12:21:01 »
no probs to encounter, gearbox caseings are the same, direct replacement useing the ecu from the 25, only thing you may have to do is if the 35 came from a petrol is to swap the bellhousing from your 25 box and you will have to use the torque converter from your engine as they are matched to the engine power.
Shackeng
  • Ramsbury
« Reply #38 on: 14 May 2011, 16:59:35 »
Thanks, yes I knew about the TC. It has to come off with the box I believe, and be fitted to the new box before it is refitted with its new bellhousing. :y :y :y
richdrury
« Reply #39 on: 14 May 2011, 20:36:11 »
yes thats right, and make sure the TC is seated right or you'll have to drop the box again and redo it as i found out this evening >:(
but the box is now in place and secured, just got to fit the rest of the bolts, torque it all up and fill with atf tomorrow then go for a test drive ;)
Shackeng
  • Ramsbury
« Reply #40 on: 14 May 2011, 22:50:03 »
Tough luck, I have been warned! :y
richdrury
« Reply #41 on: 14 May 2011, 22:56:00 »
so was i, but i still managed to get it wrong ::)
GardO71
  • Nr Oxford
« Reply #42 on: 15 May 2011, 12:17:48 »
started on the swap this evening, just the rear brace and 2 bellhousing bolts and its ready to drop, all going well so far :)
thats put the kiss of seath on it then.
i always keep a neutral mind until job is done, that way, if it goes wrong, you can't blame anyone or yourself lol
richdrury
« Reply #43 on: 15 May 2011, 13:46:54 »
box is all in and torqued up, just got to put exhaust together and try the box out now :)
richdrury
« Reply #44 on: 15 May 2011, 20:52:48 »
job all done, box filled corectly and running smooth as, and with no leaks at full operating temp :)
must say many many thanks to Albs for supplying the box at a fantastic price,  ;D
ps: do you have the exhaust - autobox rubber bungs and bolts as my box never even had the bracket let alone those bolts ;)
« Last Edit: 15 May 2011, 20:53:36 by richdrury2001 »
Pages: 1 2 [3] 4  All   Go Up
